Versalaser on Win7
npala
Versalaser on Win7
Post by npala » Sat 30 Jan , 2010 16:21 pm
I try to install Versalaser on Windows 7 Ultimate, and I receive this error:
"Could NOT Add Port Monitor. DLL(s) may be Locked or NOT Existing"
Somebody can help me?
Thanks.
Re: Versalaser on Win7
Post by Martin » Sat 30 Jan , 2010 17:54 pm
What model of VersaLaser do you have?
ULS Ausrtia report that the VLS & PLS range will run on Win 7, 32 bit operating system.
Are you on the latest software?
npala
Post by npala » Sat 30 Jan , 2010 18:24 pm
Martin wrote:What model of VersaLaser do you have?
I have VLS 3.50 /40W and I try to install 5.24.38 and 5.26.45 (from this forum), and I receive this windows :
1. UCP, with text:"
2. Unable to Open Monitor, with text:" The printer name is invalid."
3. AddPort.exe, with text: "AddPort.exe has stopped working : Check online solution and close program / Close the program "
Details: APPCRAS ...... ntdll.dll ....
4. Printers, with text: "The arguments are invalid"
5. OEMSetup, with text: "Timeout Waiting for Driver to Install"
Is possible to be a problem because I have Windows 7 64bit.
Post by Martin » Sun 31 Jan , 2010 11:43 am
I think ULS have a Beta version that is 64 bit. You may be best contacting them for a copy.
npala
Post by npala » Mon 01 Feb , 2010 7:58 am
Martin wrote:I think ULS have a Beta version that is 64 bit. You may be best contacting them for a copy.
ok - thank for help.
npala
Post by npala » Fri 05 Feb , 2010 13:26 pm
I install 5.27.48 on Windows7 x32bit and is ok, but I have another problem: on Settings don`t apear "Manual Control" tab !
Is necessary to instal another program?
P.S.: 1-Touch Photo is SUPER!
win7 with 5.27.48.jpg (114.18 KiB) Viewed 13880 times
Post by Steve » Fri 05 Feb , 2010 16:45 pm
You need the advanced driver which we do not supply.
npala
Post by npala » Fri 05 Feb , 2010 20:10 pm
Steve wrote:You need the advanced driver which we do not supply.
I have "UlsAdvanced 2.9.9" , but work with whith 5.27.48? - because I have this software from 1 year ago.
Post by Martin » Fri 05 Feb , 2010 22:43 pm
When you install the software if you select a bigger laser (VLS 4.60) at the same time as the VLS 3.50 then the advanced driver will be installed automatically. The 4.60 will show up as a printer but is never used.
npala
Post by npala » Sat 06 Feb , 2010 9:54 am
Martin wrote:When you install the software if you select a bigger laser (VLS 4.60) at the same time as the VLS 3.50 then the advanced driver will be installed automatically. The 4.60 will show up as a printer but is never used.
Thank you - now is ok.
