Not cutting
Helen
Hardware/Software: Milling, 3D UP!, Laser, HP 3D Printer,
Not cutting
Post by Helen » Thu 27 Feb , 2014 13:49 pm
Our VLS6.60 is not cutting today. It worked fine 24hrs ago. The red beam is present when lid is open, but not when closed and moving. No mark is being made. I have checked the mirrors, nozzle, z height. Any thoughts?
Re: Not cutting
Post by Martin » Thu 27 Feb , 2014 18:20 pm
Try disconnecting the USB cable from the computer while the machine is powered up? You should get a disconnect error countdown. Then when you plug it back in it will download the firmware. I have seen this work several times.
Helen
Re: Not cutting
Post by Helen » Fri 28 Feb , 2014 12:47 pm
Fantastic! Thankyou, it worked first time.
