VL-300. Advanced Driver
Since my last post I have my VL-300 working properly. I have just cleaned both mirrors and the lens and will now cut through 3mm acrylic with ease (had to do three passes in order to cut through yesterday!)
I have used a larger Universal Laser at school (I'm a DT Teacher) and am very used to chnging the Power and Speed to work with different materials. Is this not an option with the VL-300? I seem only to be able to select te material from the pop up. The only setting that can be changed are Intensity (I assume this provides more power to the laser on settings from -20 to +20, should this be set to anything inparticular?) and Tuning (No idea what this does!). Is it possible to operate a VL-300 by setting a power and speed value?
The only other problem I have is with the extractor. The LED's do not light up on the unit. I had to change the fuse for the compressor as this did not work but the fuses for everything else all look ok. THe extravtor only has a grren button (ON) and a red button (OFF). I though I had read somewhere that the laser can communicate with the extractor to tell it when to come on. How is this possible.
Many Thanks in advance
- bradders
Re: VL-300. Advanced Driver
You need the file UlsAdvanced.exe to activate the Advanced Driver.
- UlsAdvanced.rar
- (54.35 KiB) Downloaded 1256 times
The older lasers had additional USB ports on them to connect the extractor to the laserI though I had read somewhere that the laser can communicate with the extractor to tell it when to come on. How is this possible.
Yeah I see the USB hub on the back of the LAser, but there are no USB's on the extractor unit. Maybe they offered them with a different extractor which had them at some stage!
Bradders, that file seems to be the newer VLS driver, it doesn't seem to work with my VL-300!
Thanks for the quick reply again,
- bradders
Windows XP (ONLY)
• Power ON your PC. If your PC is already ON, close all programs.
• Click Start, and then click Printers and Faxes.
• Click Add Printer. When the Add Printer Wizard dialog box appears click Next.
• Choose Local Printer attached to this computer and deselect (uncheck) Automatically detect and
install my Plug & Play Printer and then click Next.
• Use the following Port (LPT1) should already be selected. We recommend the use of this port. If the
system is connected to a different port, choose the correct port from the dropdown list and click Next.
• Click Have Disk, insert the printer driver CD-ROM, which can be found in a sleeve attached to the
rear cover of this manual, and then click Browse. Locate the ULS2000.inf file in the
\WIN2000_XP_Vxxxx\ folder (where xxxx is the version number), click Open, and then click OK.
• When the list of printers appears, choose your model from the list. If you are unsure of your model’s
name, turn on the laser system and the model name will appear in the control panel display while the
system is initializing or the model name can also be found engraved on the serial tag found on the
backside of the machine. Click Next.
• The Name your printer dialog box will appear. You may rename the printer if you like, however, we
suggest that you leave the name unchanged or simply add a word or two after the name (keeping the
name, including blank spaces, under 31 characters). Choose to whether or not you would like it to be
your default printer and then click Next.
• The Printer Sharing dialog box will appear. Unless you are planning to share the laser system on a
network, select Do not share this printer. Please consult your network administrator if you would like
to share the laser system on your network.
• Select No to Do you want to print a test page and then click Next.
• Click Finish to close the wizard. When the Windows Logo Testing warning appears click Continue
Anyway.
• After the driver finishes installation, store your printer driver disk in a safe place for future reference.
Anyway.
Are those instructions to get the advanced driver working on a VL300 then ?Windows XP (ONLY)
• Click Add Printer. When the Add Printer Wizard dialog box appears click Next.....
- bradders
I got those from a Versa Laser manual that was for the Advanced Driver. But I have just installed the Versa Laser 1.29.5 driver from our web and is has installed a VL300ADVANCED option in the PRINTERS and FAXES section of Windows and this has the Advanced Driver options.
I have tried the work around above but still to no avail. I do not get any advanced settings this way. I have downloaded the v1.29.5 drivers and the v1.3 ones from the denford site but does not work with either.
I wonder if yours has already got the drivers installed? I do not have the CD only what I have downloaded from the site.
P.s I have just etched onto some translucent polypropylene and it has come out red. Is this normal? I'll try and put a picture on if I can!
It may be vapour from previous cut jobs off the honeycomb bed. Can you try it with a custom fixture to lift it away from the bed.
