Turn 270 Pro General questions
All info relating to the Denford Turn270 and NewTurn270 CNC lathes
Jimsiss
Hardware/Software: Turn 270 Pro
Post by Jimsiss » Fri 04 Aug , 2023 19:13 pm
Hi, I’ve just picked up a Turn 270 Pro to tinker with in my shed. I’m a CNC Turner by profession so it’s not new to me, having used mainly Fanuc machines most of this is familiar.
A few questions and info requests:
-First of all I’ve had the machine up and running and managed to set the tools and program a few basic test pieces by hand (still getting to grips with the software before I let it program anything). What is the white button for on the front of the machine? Optional extra Chuck open/close?
-Are there any pictures of the optional extras for the lathe? I’m interested to see how tailstock is fitted etc. (mine doesn’t have a tailstock but I was just curious as I couldn’t find much info on it and the other extras.
-Has anyone turned Titanium on a 270/Pro? I’ve turned lots of Titanium so I know what it’s like to work with and in theory anything is possible with enough coolant and small enough cuts.
-Has anyone fitted ER Collet chucks and Carbide micro/mini boring tools? I don’t really like the drill holding setup so I’ve bought some 20mm shank er20m collet chucks to turn/grind down to 19mm and shorten (19mm seems a very strange size to make the internal tool pockets on the turret). I’d like to get some smaller bores machined so I was looking at making up some carbide boring tool holders to fit the turret.
I’m not a fan of the work offset system having used G10s a lot.
I’m sure there will be many more questions to come :roll: :lol:
DavidB
Re: Turn 270 Pro General questions
Post by DavidB » Sun 06 Aug , 2023 16:57 pm
I can't help with the Turn 270 questions but regarding the internal tooling pockets they sound the same as on my Orac toolchanger and I believe 3/4" ID as that's 19.05mm. 3/4" round bar is a spot on fit although I haven't used them so far.
Post by Martin » Wed 09 Aug , 2023 13:48 pm
The white button on the front should be for indexing the turret manually.
Jimsiss
Post by Jimsiss » Sun 13 Aug , 2023 10:14 am
1 down 3 to go.
Jimsiss
Post by Jimsiss » Fri 25 Aug , 2023 18:26 pm
Managed to get a micro boring bar holder made up, I might have gone a tad overboard taking it to 19mm 🤣. Made from an old offcut of 20mm boring bar. Hopefully I’ll be able to get a few test pieces made up over the next week off work…
Jimsiss
Post by Jimsiss » Sun 08 Sep , 2024 12:52 pm
Managed to make a part last year and been that busy with work etc that the machine has been stood for a year :roll:
I have not long had my new laptop through to run the machine from (Framework 16) so that means it can be set up again.
I was thinking back to the connection process and remembered seeing there were 3 ports on the control board. One USB-B which is connected to the bulkhead pass through to run the machine, a serial port and an Ethernet (RJ45). Can the machine been connected via the other ports (more specifically the Ethernet port)?
Post by Martin » Mon 09 Sep , 2024 7:45 am
No we have never used the ethernet port.
USB & Serial but USB is faster.
