Homing Downwards Now!
All info relating to the Denford Turn270 and NewTurn270 CNC lathes
Jimsiss
Hardware/Software: Turn 270 Pro
Post by Jimsiss » Thu 31 Aug , 2023 17:36 pm
Finally got to the point of setting the new tools. Set two and then sent it home to change to the next tool, Z axis homed correctly as before but now X goes down until it hits the bottom of the machine. If I manually jog it into position it knows when to stop as it hits 0.000 but I press to home X on its own and the axis and readout goes negative until I hit the E-stop.
Anyone any ideas?
Jimsiss
Re: Homing Downwards Now!
Post by Jimsiss » Sat 02 Sep , 2023 14:00 pm
I think I remember the actual spindle speed being 0 too when it was spinning up.
Jimsiss
Post by Jimsiss » Sat 02 Sep , 2023 15:28 pm
Might have found the issue, looks to have lost the connection on the limit switch. Can’t easily see to put it back on though
Jimsiss
Post by Jimsiss » Sat 02 Sep , 2023 16:50 pm
Done. It took about 2 hours total but it’s sorted. Spindle speed was working after checking the fuse so that’s not an issue. E-stop relay has one burnt contact though so that might need sorting in the near future.
Fault was the wire came off the limit switch, it was a terrible loose crimp so I tightened it with pliers (whilst under the x axis 🙄). The wire was very short so that took the longest to get back onto the terminal, not easy working in a mirror under the slide way.
