I am having difficulty find information on a SEM type 30X2-44L spindle motor ( Photo of plate enclosed) can anyone help with information on identifying the wires coming out of the motor.
I have contacted SEM themselves who claim to had destroyed all information on obsolete motors can anyone please help.
Dave Mann
SEM Spindle Motor
SEM Spindle Motor
- scan0002.jpg (236.3 KiB) Viewed 7959 times
Re: SEM Spindle Motor
You Should have 6 wires.
2 x Armature
2 x Tacho
2 x Thermal trip
2 x Armature
2 x Tacho
2 x Thermal trip
Thanks very much.
I know the armature wires which seem to have an earth wire,
but how can I identify the others?
The thermal wires should be a dead short & the tacho should give you a feedback of 9.5 volts DC per 1000rpm so if you put a meter on it & spin it manually you should see a change in the voltage.
Thanks Martin that is perfect, I'll be able to sort this out now.
Thanks again and happy Easter.
Dave.
Dave.
- Iron-Man
- CNC Apprentice
- Hardware/Software: Modified NovaTurn with Yaskawa AC Servos +-10V, PathPilot running on a GizmoSphere 1 with Ibob2 PCIE interface that I designed. Denford Triac to be modified with AC Servos.
davemusicmann wrote:I am having difficulty find information on a SEM type 30X2-44L spindle motor ( Photo of plate enclosed) can anyone help with information on identifying the wires coming out of the motor.
Dave Mann
Dave I have this manual but it does not have a lot of information.
It may help,
Iron-Man
- S.E.M. MT_Technical_Data_Manual.pdf
- (1.94 MiB) Downloaded 879 times
