Triac power problem
- Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3 - Location: Quatroland
Re: Triac power problem
so you should have the 0-10v variable voltage on 4 and 6, with 4 being positive. If you're not getting any voltage on 4 and 6 and you've specified a speed and commanded a spindle start on the triac, this will probably be the fault. Pin 5 should have a reference voltage on it, so check across 5 and 6 for 10v. If you get 10v across 5 and 6, remove the wires from 4 and 6 and connect 4 and 5 together, then you should get full speed when you command a spindle start.
Again be careful here as the 0v of the 0-10v is not connected to ground.
- CNC Apprentice
- Hardware/Software: Triac '87 converted to mach3
Orac '85 converted to mach3
I have been out and tested for those voltages.
I have no variable 0-10Vdc between 4 and 6.
There is also nothing between 5 and 6, so I presume that the reference voltage is missing, and thus causing the fault?
Is this voltage fused somewhere?
Thanks again
Paul
Thanks again
Paul
You could always fit a potentiometer to the 3 connections (I'm sure the manual I referred to earlier shows the speed input as a pot)
Then you'll know for sure that's the issue.
- CNC Apprentice
I had thought about a pot, but if the reference voltage is not there, surely that wont work?
thanks
Paul
thanks
Paul
Ah yes sorry - I hadn't seen you mention the reference voltage was missing.
I'd certainly expect 10V between two of the speed input pins (5 and 6, Lo and Hi according to the B&P manual)
Try it again with the wires disconnected from 4,5 and 6...
- CNC Apprentice
Ok,
I have tested the voltages with the wires disconnected, and between pins 4 and 5 I get approximately 7.8Vdc when spindle speed was set at 1000rpm. It then steadily decreased until the machine faulted out.
When I connect the wires back on, the voltage is not there.
I am guessing that this is what you expected to happen?
Any ideas why?
Here is a pic of the terminals on the fanning strip.
I really appreciate the help guys
Any ideas why?
- IMG-20111115-00045 (Small).jpg (53.89 KiB) Viewed 8581 times
4 Quatros
3 Oracs
2 Easiturn atc
there is one other thing to try on the fanning strip.
You can manually run the spindle by removing the wires from 4, 6, 7, 8 and 9.
Then get a PP3 9v battery and connect it up to 4 (+) and 6 (-). and take 8 and 9 to a switch. Turn on the triac and close the switch, this should give you near full speed.
PS. have you removed the jumper wire you put on the main contact strip.?
- CNC Apprentice
Hi angel-tech,
Thanks for the reply.
I have just tried that, and still nothing at all. Does tis mean that I need to look for a replacement Brown&Pestell drive because this one is caput?
Paul
Paul
4 Quatros
3 Oracs
2 Easiturn atc
