Page 2 of 2
Posted: Mon 09 Oct , 2006 21:17 pm
Glad you worked it out
Can you qoute a couple of examples of the string to number conversion so anyone else could do the same ?
Posted: Tue 10 Oct , 2006 21:01 pm
by Karl
I'm going to check with my friend that figured it out and if it's OK with him I'll post the reply I got from him. The data is(as I remember it):
79 bytes for each line of startuen data
byte 1 = line #
Byte 2 = ?
Byte 3 = 1 to indicate if the number in byte 4 is G, 2 if it is an M code
Byte 4 = value of G or M code
Byte 5 = # of valid characters in the remark statement to follow
Byte 6 to 37 = ascii text of remark statement
Byte 38 to 44 X value in mantissa/exponent format
Byte 45 to 51 Y value
Byte 52 to 58 F value
Byte 59 to 65 R value
That's about how it fell out. I hope it helps someone else.
Karl
Posted: Wed 11 Oct , 2006 15:48 pm
And after all that ....... Mr Magoo finds a DOS utility which takes G-Code text files and creates an STA and a STS file
Here it is:
Re: Starturn 4 '.sta" format
Posted: Mon 12 Oct , 2009 17:07 pm
by robtjhill
i have run in command prompt but, cannot read nc file is displayed where it should have converted blocks
can someone tell me what i am doing wrong
Posted: Tue 13 Oct , 2009 7:48 am
by Mr Magoo
I've just seen this post - wish I'd seen it earlier to save you folks some pain.
The attached STSPEC.TXT gives the file format the txt file should follow in order for it to be read by the conversion program. HTH
Posted: Tue 13 Oct , 2009 8:26 am
by Mr Magoo
Hi Karl...
I know it's a bit late in the day to post this, but here is the format of a Program Block record (cnc block) that is loaded / saved by the Starturn...
Code: Select all
blockno: // looks like this is a 16 bit signed integer ??
kind: // byte: 0=blank line, 1=GCode, 2=MCode, 3=comment
code: // byte: G or M Code value
commentary: // comment text (first byte is text length),then 32 bytes
parms: array [1 .. 6] of // array of 6 parameters to follow (eg x, y, z, f, r )
record // (I guess a max of 6 because of a threading block)
value: real; // float: each parameters value
filled: boolean // boolean (probably a byte): true if this parameter is used?
end
Hope this makes sense if you're pursuing you own file writer! I may be able to dig out some further notes if it helps.
Posted: Mon 28 Mar , 2011 18:50 pm
by black5f
Very late on this post! Try this...
viewtopic.php?f=46&t=3253
Tom
