Tool holder for Triac 1993
biggles
Post by biggles » Thu 03 Jan , 2008 22:42 pm
Hi,I have a 93 Triac without toolchanger.It has quick release tool holders EC-ST-055C.Does anyone know where I can buy more of these and more importantly the collets to suit.
Many thanks
clarkea1
Post by clarkea1 » Fri 04 Jan , 2008 12:25 pm
Are these the "Easychange" type of holders? If so, I think Rotagrip in Birmingham sell these new (or they did a few years back, which was the last time I saw their catalogue).
Alternatively, drop me a line as we have some of this tooling lying around at work which may be available (email clarkea7@cf.ac.uk)
Alastair
Roy
Hardware/Software: 1986 Triac modified & running Mach 3
Post by Roy » Fri 04 Jan , 2008 20:33 pm
If these are easychange then, yes they are available from rotagrip.
However i suspect the easy change holders you have came with the machine, and will accept clarkson autolock collets. (you can oftern find autolock collets on ebay)
A picture (if possible) will help us identify your holders.
biggles
Post by biggles » Fri 04 Jan , 2008 21:18 pm
I have attached a photo of the tool holder.Hope someone can identify it.
Roy
Post by Roy » Fri 04 Jan , 2008 23:10 pm
The holder is of the 'easychange' type. However the collets are not the autolock type i mentioned. I do recognise them, but not sure what they are called. 'Titanic' does come to mind, but I am not sure.
dscolwill
Post by dscolwill » Sat 05 Jan , 2008 10:44 am
I use the Easichange system avilalble from J&L the collet chucks are ER32. I have tried these in a Denford fitting and they are the same taper. Also available are drill chuck mounts with a JT6, endmill holders and a threaded boring head mount.
biggles
Post by biggles » Sat 05 Jan , 2008 11:01 am
Thanks for that. But who are J&L? Do they have a website ?
dscolwill
Post by dscolwill » Sat 05 Jan , 2008 15:06 pm
Post by Steve » Mon 07 Jan , 2008 10:15 am
Biggles,
The toolholder is an easychange as everyone has identified.
The toolholders are supplied in various forms some with collets as you have and some with a set bore.
The collet holder is ideal if you just have one holder and a range of tool sizes you want to hold but if you are trying to fit several several tools in holders then the best way is to EndMill Sidelock adaptors.
What sizes of tool do you want to hold?
The part numbers are as follows:
EC-EM06-035 6mm shank tool (tool holder length out of taper 35mm)
EC-EM10-035 10mm shank tool (tool holder length out of taper 35mm)
EC-EM12-035 12mm shank tool (tool holder length out of taper 35mm)
They are also available in 16, 20 and 25mm
We get these from Coventry Toolholders Tel: 0247664599
See attached PDF's
easychange.pdf
(344.12 KiB) Downloaded 1593 times
el$syd
Re: Tool holder for Triac 1993
Post by el$syd » Mon 20 Jul , 2009 11:48 am
Posi lock, or Pozi lock is the 055C collet.
Comes in 6, 10, 12, 16 mm sizes and hold 1.5mm to 20mm cutters.
Available from Chronos and other suppliers
