STARTURN PROBLEMS
ruben
STARTURN PROBLEMS
Post by ruben » Wed 08 Aug , 2007 18:22 pm
I get a starturn, it never was used, but all seems to be ok. the black metal case says starturn, in the main board inside it says lcb3 and it says mirac 2.0 on a chip. the manuals says "fanuc ot turning offline programming system. with desktop tutor" and it says it uses denford fanuc turning v1.0.
i downloaded fanuncld and it says on the bar on the top denford fanuc turning v1.42 but i cant load information to the controller, i conect the cable to an other pc and i prove with the hyperterminal, and the computer its transmiting the program, but nothing happends with the controller and the lathe.
do i need to configurate the controller or something like that?
the destop tutor works ok but i cant run the program in the lathe. pressing the buttons home and auto nothing happends
the problem is the software, the controller or the lathe?
Post by Denford Admin » Thu 09 Aug , 2007 16:44 pm
Hi - sorry I can't really help, I don't know anything of the older machines.
There may be bits of information relevant on this forum, and you if you could send a photo of the machine and electronics, it may help someone else know how to advise you.
ruben
Post by ruben » Thu 09 Aug , 2007 19:12 pm
i could get the original software and the dongle key, it was a box with 5 51/4 disks, they was in perfect conditions, the 5 disks was named:
FANUC OT DESKTOP TUTOR IBM version 1.34 Parallel key 24-Mar-1992
FANUC OT QWERTY system IBM version 1.34 Parallel key 24-Mar-1992
POST PROCESSORS DENFORD LATHES
DENFORD DRIVERS DISC IBM
FANUC OT -EXAMPLE -TEXT FILES
the software and the driver(the black metal box) are working ok but the lathe dont move.
i think i most configure the driver(the black metal box) with the disk POST PROCESSORS DENFORD LATHES but i dont know what file i most install.
the files in the disk are:
-PPETURN.EXE -PPFANUCT.GO
-PPETURN.GO -PPFANUCT.MSG
-PPFAGOR.EXE -PPFANUCT.TXT
-PPFAGOR.GO -PPOORAC.EXE
-PPFAGOR.MSG -PPOORAC.GO
-PPFAGOR.TXT -PPORAC.EXE
-PPFANUCT.EXE -PPORAC.GO
-PPSTURN.GO -PPSTURN.EXE
when i execute one of the fanuct.exe files says
FANUC TURNING POST-PROCESSOR 1.00 (6 April 1988 )
Denford Machine Tools Ltd ( Software Department )
ENTER CAM FILENAME:
if i enter a file name like "fanuc" it says:
Post-processing C:\TORNO\FANUC.LGP
Creating C:\TORNO\FANUC.FNC
CAM file not foud
and thats all
what can i do to install my machine?
can anyone supply me with a fanuc or mirac instalation manual?
i add some pictures of my machine
STARTURN
MAIN BOARD
BLACK METAL BOX
Mr Magoo
Post by Mr Magoo » Tue 14 Aug , 2007 10:12 am
I think the software you require for your machine is called FANUCSLD.EXE
You can download it here
NOTE that you can not send G codes directly to the machine electronics via the RS232 link. You need to load a G Code program into the FANUCSLD software, then use this to communicate with your machine.
ruben
Post by ruben » Tue 21 Aug , 2007 0:33 am
I downloaded FANUCSLD and Dosbox for run it and its working ok
but when I'm working on step mode, for each time i press the x axis bottom the machine moves two steps. When I want to move the x axis 1 mm it moves 2 mm.
Is there a form to calibrate the X axis motor?
How can I solve this problem?
Mr Magoo
Post by Mr Magoo » Tue 21 Aug , 2007 0:58 am
Is the problem only when in STEP JOG mode, or also in JOG and AUTO modes too?
I think the machine works in Diameter mode, this means that when the display changes by 1mm, the X motor moves by 0.5mm (because the final workpiece diameter will have changed by 1mm). If this is the reason then this is normal!
Post by Steve » Tue 21 Aug , 2007 5:07 am
I think Mr Magoo is right.
Try moving the z axis and see if this moves the correct distance?
If so then the machine is OK.
