Starturn 8 cnc program/software
nickyjones2
Post by nickyjones2 » Fri 20 Apr , 2007 3:12 am
We have acquired a starturn cnc machine in the year 1990's but we have not used the said machine because there were no software and manual included.
In line with this we would like to request your good office to download the starturn 8 software and manual. So we can use this machine for instructional purposes in our school.
Would like to know the functions of the following parts dc speed controllers, slave board, and bus board. i would also like to know if the RS 232 serial link can be change to universal serial link.
Hoping for your kind consideration.
Post by Denford Admin » Thu 03 May , 2007 10:31 am
Hi - have you tried this Startutn software from here :
https://www.denford.ltd.uk/index.php?opt ... &Itemid=51
There are also lots of other bits of Starturn information on this forum - you just need to spend some time reading through the relevant posts
If you could attach a photo of the machine and the electronics, we may be able to help find more information
You would never get the machine working with USB as it is - you would have to retrofit it with some new CNC controller and PC software
nickyjones2
thanks..
Post by nickyjones2 » Tue 08 May , 2007 1:56 am
thank you for the software. i like for a copy of the manual so that i can try to run the machine. Is it possible if i change the serial port of the machine to printer port?
thanks..
nickyjones
Post by Denford Admin » Tue 08 May , 2007 9:15 am
To run the machine from the printer port (or possibly USB) you would have to look at alternative software to control the machine.
See this topic where another member has upgraded to use Mach3 to control is original StarTurn 4:
viewtopic.php?t=452
Re the drawings and manuals try these posts:
viewtopic.php?t=396
viewtopic.php?t=922
I've just uploaded a DOS turning manual here:
viewtopic.php?p=3108
nickyjones2
sending pics...
Post by nickyjones2 » Wed 09 May , 2007 2:41 am
i'd like to send some pictures of the machine... how can i send some pictures?
thank you for the manuals.
good day..
nickyjones2
Post by nickyjones2 » Wed 09 May , 2007 8:37 am
Post by Denford Admin » Wed 09 May , 2007 8:51 am
The easiest way is to Add Attachment..... see this post for more help:
viewtopic.php?t=823
** Please make sure the image is resized down to less then 1000 pixels wide and is compressed format like JPG or GIF - not BMP or TIFF **
If you use then you must provide a link to your own picture and web hosting location
nickyjones2
starturn pictures
Post by nickyjones2 » Thu 10 May , 2007 3:44 am
starturn 8
starturn 8
nickyjones2
starturn pictures
Post by nickyjones2 » Thu 10 May , 2007 3:46 am
starturn 8
nickyjones2
starturn pictures
Post by nickyjones2 » Thu 10 May , 2007 3:48 am
starturn 8
nickyjones2
starturn pictures
Post by nickyjones2 » Thu 10 May , 2007 3:49 am
starturn 8
nickyjones2
starturn pictures
Post by nickyjones2 » Thu 10 May , 2007 3:50 am
starturn 8
nickyjones2
starturn pictures
Post by nickyjones2 » Thu 10 May , 2007 3:51 am
starturn 8
nickyjones2
starturn pictures
Post by nickyjones2 » Thu 10 May , 2007 3:53 am
starturn 8
nickyjones2
help!
Post by nickyjones2 » Thu 10 May , 2007 3:57 am
i hope you can help me run these machine for educational purpose.
thanks
nickyjones
Post by Denford Admin » Thu 10 May , 2007 9:48 am
We can do our best, but I'm afraid we can't just wave a magic wand and get your machines working :!:
We can no longer officially support this age of machine - most of us here have never seen a Starturn 8, let alone used one.
We can help with general advice and how other forum users have upgraded their machines to use windows based software, you really need to investigate the best way to get them working for yourself.
nickyjones2
help!
Post by nickyjones2 » Fri 11 May , 2007 2:57 am
can you help me look for a starturn 4 or 8 manual cause the only manual i have here is the novaturn manual and they are different. i can not use the novaturn manual as a reference for the machine. if you can only share to me a manual of any starturn machine that could help me alot.
thanks..
nickyjones
Mr Magoo
Post by Mr Magoo » Sat 12 May , 2007 13:48 pm
The Starturn machine you have is very old and will ONLY run with the software here...
viewtopic.php?t=192
This software can only run in DOS mode via RS232.
It can NOT run using USB
It can NOT run inside a Windows DOS box
It can NOT run using a USB <-> RS232 converter
Sorry to be negative, but with a machine that is almost 20 years old you must be thankfull if you manage ot get it to run at all !!!
davidimurray
Post by davidimurray » Mon 14 May , 2007 8:20 am
HI
As Mr Magoo said without major rebuilding / rewiring the machine will only run off serial comms in Dos.
I have a manual for a Starturn 4 for a BBC. Not sure how different the 2 systems are.
Dave
nickyjones2
manUAL
Post by nickyjones2 » Fri 25 May , 2007 2:56 am
can i try the manual for starturn 4. i think starturn 8 and 4 are the same.
