StarTurn image gallery
- starturn.jpg (54.12 KiB) Viewed 20243 times
- Hardware/Software: vertical router and mirac lathe
Re: StarTurn image gallery
Do you have any photos of a Starturn PC, or any info on these. I have just bought one but not yet collected it. It has lathe cam designer 1.1 and it says it comes with "Starturn PC Software Version 2.23" I can find no mention of this on the forums was this similar to VR Turning?. It is a slant bed similar to a novaturn but with a square case.
Kind regards
John
Kind regards
John
- starturnpc.jpg (9.32 KiB) Viewed 20221 times
jcf
The bottom 2 links will be relevant manuals to the software that will run your machine:
DOS machine software PLUS Photos and Drawings:
viewtopic.php?t=196
Dos Software free downloads:
https://www.denford.ltd.uk/index.php?opt ... &Itemid=51
Starturn problems:
viewtopic.php?t=1113
Dosbox:
viewtopic.php?t=844
Fanuc OT offline turning Programming manual DOS version PDF:
viewtopic.php?f=15&t=2324
DOS Turning Software Manual:
viewtopic.php?f=15&t=953
viewtopic.php?t=196
Starturn problems:
Dosbox:
viewtopic.php?t=844
This is the Starturn 5 (ST5) where the Novaturn used to be known as the Starturn 6
(How the obviously older Starturn 4 and 8 fit in I don't know
- Starturn PC / Starturn 5
- Starturn-5.jpg (103.42 KiB) Viewed 20036 times
Starturn 8 with BBC micro
- starturn8-bbc.jpg (74.95 KiB) Viewed 19738 times
