Connection issue
v8boy
Hardware/Software: Denford Novamill
Connection issue
Post by v8boy » Wed 22 Aug , 2012 17:38 pm
Hi there,
So i have finally managed to get the software to install properly for milling vr 2.31, next problem is that my the software can't find the machine. to get this far i installed a new serial port into the PCI express. any ideas???
Many thanks in advance!
Nic
Re: Connection issue
Post by Martin » Wed 22 Aug , 2012 23:09 pm
Check that it is a Denstep top card with a version 2.0 or 2.1 eprom fitted.
Make sure the com port is set up as Com 1,2,3,4 or 5.
Right click on the machine link icon in VRMilling & select "serch for machine".
You can also try to connect using Mintman.exe which will be instslled in the VRMilling directory.
v8boy
Post by v8boy » Thu 23 Aug , 2012 9:17 am
Hi there, thanks for the advice!
Well i have a smartstep card with an upgraded erpom 2.1.
In vr milling under RS232 setup i have no option to select which port, the box is blank!
Mintman can't find anything, Find machine does not work.
So maybe there is a problem with my RS232 port.... maybe this is more of a windows problem than Denford..
On the eprom board it display the number 8?
the control box appears to be working as it powers up, i can open the lid, i can hear something in the mill head happening so hopefully there is nothing wrong in there.
Thanks again!!!!!!!!
Post by Martin » Thu 23 Aug , 2012 9:57 am
Check the settings for the USB device in the device manager tab. It should be under ports. If it is set above 5 then click on the advanced tab & change it.
In VRMilling if you go to Setup, then Setup Machine Parameters (password is denny) then communication you can alter the com port to suit.
v8boy
Post by v8boy » Thu 23 Aug , 2012 10:11 am
thanks for the advice but there is no improvement.....
Post by Martin » Thu 23 Aug , 2012 10:41 am
How are you connecting? Make sure it is a RS232 cable & not pin to pin.
v8boy
Post by v8boy » Thu 23 Aug , 2012 11:55 am
hi there, i am using a male to female RS232 cable with a gender convertor on the end.
Post by Martin » Thu 23 Aug , 2012 12:26 pm
Check your RS232 cable against the drawing.
viewtopic.php?f=54&t=728
Post by Denford Admin » Thu 23 Aug , 2012 14:39 pm
I'd also check that the COM port is available to windows - look in device manager - is there a COM port listed ?
There may be some software from the PCI serial card manufacturers...it could have created a COM number too high for VRMillling to recognise (COM1 to 8 was usually the max.)
v8boy
Post by v8boy » Sat 25 Aug , 2012 11:19 am
Thanks guys, all sorted now!!!
see you when the next problem occurs!
Post by Steve » Tue 28 Aug , 2012 8:13 am
What was the problem in the end?
