Triac vs Novamill, which would you purchase ?
Iron-Man
Hardware/Software: Modified NovaTurn with Yaskawa AC Servos +-10V, PathPilot running on a GizmoSphere 1 with Ibob2 PCIE interface that I designed. Denford Triac to be modified with AC Servos.
Post by Iron-Man » Tue 10 Jul , 2012 22:01 pm
I have been searching for a Novamill for some time now. One has become available but I have also found an older Triac. I like the smaller size of the Novamill but the Z axis is very limited. I would like to know what are the real trade-offs of a Triac vs Novamill. I will be starting a retrofit to AC servo motors for a ( Novaturn / Triac or Novamill ). Any input would be appreciated.
Thanks,
Iron-Man
Re: Triac vs Novamill, which would you purchase ?
Post by bradders » Wed 11 Jul , 2012 8:53 am
Iron Man,
Condition, age and usage would be my prime concerns before purchase. If you are concerned about Z axis travel on the Novamill then go for the Triac. Work that will fit on a Triac may not fit on a Novamill.
Post by Denford Admin » Wed 11 Jul , 2012 15:29 pm
.. and the Triac can be modified fairly easily to give even more usable height:
viewtopic.php?t=318
Iron-Man
Post by Iron-Man » Wed 11 Jul , 2012 20:18 pm
Thanks for all the replies. The machine is like the one listed on this site. It does not have the TV monitor. From what I was told and could inspect, it was hardly used. There were no sign of any rust etc.
Thanks all;
Iron-Man
triac image.jpg (29.25 KiB) Viewed 8473 times
Post by Denford Admin » Thu 12 Jul , 2012 9:20 am
Yep - I'd go for the Triac - the casting will be much more rigid... especially if you're fitting servos.
