Hi.
I am looking for the dimensions/hole locations of the drill/boring bar holder block used on the Mirac tool changer turret.
Mirac Tool Turret Drill Holder
- 2.jpg (240.21 KiB) Viewed 10113 times
Re: Mirac Tool Turret Drill Holder
Hello, have you find the information?
Denford Mirac 1996 / Charlyrobot CRA2
Hello
Unfortunately no,
Unfortunately no,
Odd that they should all be missing. Give me a few days and I'll produce some kind of drawing for you. Most of the details can probably be worked out from the holes in the turret though. They're used in conjunction with D25 round tool holders.
- IMG_3091.JPG (114.34 KiB) Viewed 9440 times
- IMG_3089.JPG (230.4 KiB) Viewed 9440 times
- IMG_3088.JPG (363.46 KiB) Viewed 9440 times
You'll be able to get most of the details you need from the pictures and by measuring the positions of the dowel holes and M6 tapped holes in your turret. I've attached a sketch showing other dimensions.
Note that the tool holders aren't as long as the sides of the turret's octagon and the toolholders line up with the bottom edge when viewed from the front.
I would suggest boring the 25mm holes using a boring tool held in the chuck. That way the drills will enter the exact centre of the work piece. The machine offset required for drilling holes should be shown on the machine somewhere. Use this offset when boring the holes.
Max.
Max.
- Scan_20240619 (745x1024).jpg (43.56 KiB) Viewed 9386 times
- IMG_3096.JPG (237.79 KiB) Viewed 9386 times
- IMG_3093.JPG (214.86 KiB) Viewed 9386 times
- IMG_3092.JPG (238.14 KiB) Viewed 9386 times
