hello
gilles310
hello
Post by gilles310 » Fri 16 Jan , 2015 14:49 pm
i'm in trouble with my miracpc:
it'seems what the soft of the mirac (mirac v1.47) don't see at all the denford desktop tutor.
it seems what all leads are plugged correctly, and the machine worked perfect before.
the red led on the tutor is light normaly.
the tutor sometimes work but only few seconds, more often it do nothing.
somebody could give me the wiring plug to plug, from the db9 to the db25?
i didnt find it on the forum, after lang search.
someone know something about this trouble?
thank, gilles
Re: hello
Post by Martin » Fri 16 Jan , 2015 17:48 pm
The desk top tutor is connected via what we call a pin to pin cable.
https://www.tech-faq.com/9-to-25-pin-ser ... inout.html
gilles310
Re: hello desk top trouble on mirac
Post by gilles310 » Fri 16 Jan , 2015 18:13 pm
thank for the prompt answer martin
i find:
db9 to db25 :
2 to 20
3 to 2
4 to 3
5 to 8
6 to 22
7 to 5
8 to 4
this seems different than your exemple, but i'm not shure if my cable is good or not,
did you think that i've to rebuild a lead like your example or not?
gilles
TDIPower
Re: hello
Post by TDIPower » Fri 16 Jan , 2015 21:32 pm
pin 2 and pin 3 are the transmit and receive pins on both the 9 way and the 25way so these must be connected to each other (normally 2 to 3, and 3 to 2)
gilles310
Re: hello
Post by gilles310 » Fri 16 Jan , 2015 22:51 pm
thank pete
so i will buy the lead on the link martine gave to me
gilles
Re: hello
Post by Martin » Fri 16 Jan , 2015 23:54 pm
We used to supply a Lindy cable like this along with the desk top tutor.
https://www.lindy.co.uk/cables-adapters- ... emale-p528
gilles310
Re: hello
Post by gilles310 » Sun 18 Jan , 2015 15:44 pm
hello
i find a lead as says martin, it as no pins 1 and 25 on the db25, i try on my lathe and it work again.
just no more red led on desktop and led coolant does not work .
so i've bought the lead near lindy.co.uk. it will be here thursday.
big thank to you, marvin and pete.
gilles
TDIPower
Re: hello
Post by TDIPower » Sun 18 Jan , 2015 17:31 pm
thanks for that link, if I hadn't had a selection of connectors and bits of cable I couldn't have bought the bits to make a lead for that price!
hope it all works for.
gilles310
Re: hello
Post by gilles310 » Tue 20 Jan , 2015 15:42 pm
i just receive the lead from lindy.co.uk and now all work nice. :D
gilles
TDIPower
Re: hello
Post by TDIPower » Tue 20 Jan , 2015 20:40 pm
great news!!
