Squeeking on the z axis
Posted: Mon 14 Nov , 2016 10:47 am
by Phil
Hello
After a few years light use our school vertical router has suddenly started making a worrying noise. Jogging on the z axis there is an almighty squeeking.
Perhaps there is some oiling required but it is beyond my knowledge. I have never seen any documentation about maintenance.
I have some course work waiting to be cut but await your response.
Phil
Re: Squeeking on the z axis
Posted: Mon 14 Nov , 2016 12:31 pm
by Phil
Upon further investigation I see the accordion gaiter below has come lose. It appears some dust has gotten into the z-axis thread which is causing the problem.
My proposed course of action:
1) Blow out as much dust as possible with air.
2) Lubricate
3) clip back into position the gaiter
Does that sound like a reasonable approach? Do I need to lubricate and if so with what?
Phil
Posted: Tue 15 Nov , 2016 10:25 am
Hi Phil
Take a look at page 30 of the user manual as attached.
Posted: Tue 15 Nov , 2016 10:38 am
by Phil
Hello Martin
Thanks very much for that.
Phil
Posted: Tue 15 Nov , 2016 16:49 pm
by Phil
We are back up running after some overdue maintenance. Now I see we have a broken part that needs replacing.
The most forward metal plate clip that holds the accordion gaiter has bent. The actual accordion seems intact but ruffled.
Can I purchase a replacement plate or gaiter (whichever is easiest) from Denford? I cannot see it on the web site.
