Removing the 4th Axis
All info relating to the Denford MicroRouter Compact small routing machines
slickmcvic
Hardware/Software: Denford Microrouter Compact 4th axis 2005
Post by slickmcvic » Fri 24 Nov , 2017 10:08 am
Just picked up a microrouter Compact 2005.
Has a fourth axis attachment I wish to remove,any advice or documnetation for the correct procedure involved.
Thanks,
Brian
slickmcvic
Re: Removing the 4th Axis
Post by slickmcvic » Fri 24 Nov , 2017 11:51 am
Forget it,
Got it sorted a very straightforward twist and slide.....a previous post involving cut wires had me spooked!
Post by Martin » Fri 24 Nov , 2017 16:55 pm
Glad it's sorted.
slickmcvic
Post by slickmcvic » Sat 25 Nov , 2017 15:05 pm
As an add on after the removal I came into an error indicting 0% federate.
This was solved by going into setup machin parameters and unticking the “federate pot” option
FYI passwords “denny”!
