Martin wrote: ↑Fri 29 Jan , 2021 13:04 pm
Have you checked that the play is not in the leadscrew?
The leadscrew is tensioned with a nyloc that clamps up against the bearing.
You can also look at cleaning out the nut on the leadscrew which you would have to remove. The nuts have a captive spring that should allow for any wear but the internal slots on the nuts can get clogged up.
Thanks for your response Martin. You gave me confidence to strip the unit right down to the nut. I checked for play in the leadscrew en route but it was absolutely secure. It's difficult to imagine that nyloc nut coming loose. Here are a couple of pics of the nut:-
- 20210130_151310.jpg (68.59 KiB) Viewed 23547 times
- 20210130_151638.jpg (67.09 KiB) Viewed 23547 times
On dismantling the lead nut it became apparent that the black plastic threaded collet could not take any further adjustment to compensate for wear. The reason it had reached its limit was because the red outer sleeve had come to the end of its possible travel. However the collet is still capable of further tightening and this is how I intend to achieve it:-
- 20210130_152335.jpg (66.32 KiB) Viewed 23547 times
Neat eh? And at no cost
There is still the minutest bit of backlash apparent and so I will swap it with the Z-axis nut which is in pristine condition. The worn one will have an easy retirement in the ZZZzzz.... zone where it will enjoy assistance from Mother Earth in the form of gravity.
Regarding my other source of play, all 8 sliders on the X and Z rails are worn. Here is one of them:-
- 20210129_134857 (1).jpg (151.72 KiB) Viewed 23547 times
They no longer appear in the Reliance catalogue so I assume replacement plastic inserts are not available so that just presents me with a challenge. I will make my own. To that end I have a metre of 8mm nylon rod on order. I'll take a few pics as I do the job and present them here in due course.
TDIPower wrote: ↑Fri 29 Jan , 2021 18:43 pm
Cleaning is important on these machines especially as a lot of the time in schools etc they are used with model foam, MDF and balsa, it get right in your nuts worse than a day at the beach! I actually then went and found the Denford feeds/speed chart and used that as a base line and it was a good help.
Pete, I don't think the designers of this machine considered that cleaning was important, at least not in the leadscrew housings; the covers, especially the X, are a challenging task to remove, made worse by the use of unnecessarily small button headed screws. The screws may be strong enough for the job but the Allen keys and sockets are not. 3 of mine failed and I had to grind the heads off. I think I'll leave the covers off when I reassemble. Rant over.
Pete, is there a link to the feeds/speed chart you mention?
Brian
