y-axis resistance
papa_dogo
Hardware/Software: microturn/vr turning/lathecamdesigner
micromill/vr milling
y-axis resistance
Post by papa_dogo » Thu 22 Sep , 2016 12:26 pm
i'm using a microrouter v4ns. the y axis has a lot of resistance on either end of travel, so much that it causes the motor to stall as it tries to go home. i disconnected the motor and moved it by hand, finding the resistance considerable on either end of the axis. we have cleaned and lubed the slides and screw (vacuumed and blown off with compressed air and lubricated with silicone spray).
any suggestions?
Re: y-axis resistance
Post by Martin » Thu 22 Sep , 2016 12:44 pm
Try removing the 3 screws that hold the nut & winding the nut to the front. Then try it again. If it slides freely at both ends then tighten the nut when the slide is at the front which should align the nut.
papa_dogo
Post by papa_dogo » Fri 23 Sep , 2016 17:59 pm
i don't think it's the winding nut. when i removed the nut there was still resistance to movement at either end of the axis. i tried taking out the slides, cleaning them and lubricating them with silicone spray. there is still resistance. could the plastic sliding bushing be worn out/damaged? they don't appear damaged or worn out. could the slides be too close/far apart, so that they bind at the ends and not so much in the middle?
papa_dogo
Post by papa_dogo » Wed 30 Nov , 2016 15:39 pm
problem solved by inspector x from denford, see post
viewtopic.php?f=37&t=5193
