Need more info on the size of the microrouter 5 pro NS
TDIPower
Post by TDIPower » Thu 29 Oct , 2015 16:04 pm
I know there is a drawing in one of the manuals which gives a simple isometric type view then W x D x H info.
could you post up an end shot showing where the 'skids' are measured from the front also the width and height of them, the vertical front panel height to the angled section. The angle of the angled section to the front panel and the depth of the flat top (from angled section to the vertical back), Height of the vertical back.
Ill also need to know if there are any 'bits' sticking out.
I'm going to look at one on Weds and I need to know if I will be able to get it in the back of the landrover, hence needing these Dims.
Many thanks
