Car widening when using Quickcampro
- Hardware/Software: Denford Microrouter and Quickcam
Catia also used
As part of the F1 in schools program we use Quickcampro 19 to cut the cars out. I follow all set parameters as per the instruction manual but every time I try to cut a car out it elongates by about 5-10 mm from the z axis making the car wider than it should be. Quikcam is quicker than using Catia but it takes the kids longer to understand Catia that is why I want to use Quickcam. Can you give us any advice? Thanks Frank-Australia
Re: Car widening when using Quickcampro
I think you need to post a photo of the results, how you have the car fixture setup and any 3D STL models / CNC programs
