Vacuum not sucking
- bradders
Vacuum not sucking
If you are running Ver 2 VR Milling then the ROUTER MACHINE option does not have the facility in the MINT file to control a Vacuum pump. If the Vacuum is not running then you maybe have the wrong machine selected or perhaps a fuse has blown
