Extraction accessory for Denford Microrouter V4
TiagoM
Hardware/Software: Denford Microrouter V4
Versalaser VL300
Post by TiagoM » Wed 18 Mar , 2009 13:04 pm
I just made an accessory, "L" shaped, out of alluminium piping that fits into the machine extraction hose.
The extraction has improved about 70% but in order to take all the debris I would have to have something that would go around the cutter, or to get any original Denford accessory just for that purpose. Which I believe I've seen one somewhere.
Can you please give me some indications where to get it - prices, photos, reference number to order?...
Many thanks,
Tiago M.
Industrial Designer, Design & Technology Technician
Post by Denford Admin » Tue 24 Mar , 2009 10:56 am
Does your machine already have the black brushes all around the motor mounting plate ?
As far as I know, thats the only method we have for containing the dust so that the vacuum can remove it from above.
TiagoM
Versalaser VL300
Post by TiagoM » Tue 24 Mar , 2009 11:06 am
Hi, thanks for replying.
No, I don'd have the brush plates to go around the black chassis.
1 - Where can I see pictures of these plates?
2 - Where can I get them?
3 - How much are they taking in consideration that it's for educational purposes? (Without VAT)
4 - Can we get them straight from you?
5 - How soon could it be here in Lisbon, Portugal?
Thanks,
TM
Post by Denford Admin » Tue 24 Mar , 2009 12:33 pm
This image shows the brushes.
Apperently, however, we have stopped fitting the brushes so I'm not sure whether a) we can still supply them or b) they would work anyway...I guess they were removed for a good reason !
I'm sure you could experiment with something, to see if you can contain the dust for long enough to let the vacuum suck it away.
ROUTER MAIN.gif (75.13 KiB) Viewed 7005 times
