Can you help me identify my machine, and tellme what drivers and software it came with?
Micromill 2000
Ser. # 57598
Denmint v2.0/S/B19-JD5
thanx
paul johnson
Micromill 2000; Ser. # 57598 ; Denmint v2.0/S/B19-JD5
Re: Micromill 2000; Ser. # 57598 ; Denmint v2.0/S/B19-JD5
It will have run from VR Milling version 2.xx
This is the inspection document but doesn't tell you much more.
- 57598.pdf
- (42.88 KiB) Downloaded 810 times
It looks as if it will have been shipped with VRMilling Version 2 software.
It should say on the serial number label on the side of the machine.
The EPROM will work with VR Milling 2 or 5
