Motor cuts out on micromill
DSaylor
Hardware/Software: Micromill (Buckeye)
Post by DSaylor » Fri 18 Feb , 2011 18:28 pm
My micromill spindle motor cuts in and out. Sometimes the motor will not start at all. Spinning the spindle usually gets the motor turning, but it acts like an old car engine that needs a serious tune up.
Re: Motor cuts out on micromill
Post by Martin » Fri 18 Feb , 2011 22:46 pm
Have you checked the motor brushes?
DSaylor
Post by DSaylor » Tue 22 Feb , 2011 15:48 pm
What is the procedure for disassembly to check the brushes?
Post by bradders » Wed 23 Feb , 2011 9:20 am
At the back end of the spindle motor there are 2 x plastic caps with a slot in, use a coin or a wide flat screwdriver to undo.
See Exploded View of Micromill in the PDF below
You may get replacemnet brushes from here :-
Millhill Supplies Ltd.
Unit 37, Broton Drive, Halstead, Essex C09 1HB, UK
Tel: ++44 (0) 1787 472236, Fax: ++44 (0) 1787 477797
E-mail: sales@millhillsupplies.co.uk
Website: https://www.millhillsupplies.co.uk
CNCmillEX.pdf
(196.16 KiB) Downloaded 720 times
DSaylor
Post by DSaylor » Wed 23 Feb , 2011 16:06 pm
My actual thought before I contacted this website were brushes. As I look at the schematic you sent it is indeed my machine, however, there are no external brush access ports. The outside of the motor has no openings at all. It appears to open the motor can I must remove the thru bolts that hold the entire assembly together. Is this correct? Is re-assembly as easy with this motor as dis-assembly?
Post by bradders » Wed 23 Feb , 2011 16:22 pm
There were 2 different spindle motors fitted ...............
1. Access to the carbon brushes was by removing the rear end plate
2. Access to the carbon brushes was by removing the 2 x plastic securing caps at the end of the spindle motor barrel
