I have the machine powered up and running and can make the various parts move predictably, which is a good start. However, I have several questions that I am trying to find an answer to, so thought that I would ask here first.
I want to get the RS232 (serial) link running so that I can download programmes from a PC (sure beats typing – if only for error prevention!). I have read the various forum entries and understand that I need to make up a cable for pins 2,3,7 (at the PC) end. I can do this no problem – and figure out whether or not it needs crossing over – but before I can get that far, I have a couple of questions:
- - The serial socket at the lathe end is something odd. It is a circular one the size of a DIN plug but has a different pin configuration to standard 6-pin DIN, which consequently won’t fit. Anybody know what type of socket this is, so that I can try and order up a matching plug?
- Can the lathe be driven directly by the PC, and if so, what software is needed at the PC end to do this?
- How do I start the ‘data link’ programme on the controller? And when I get it running, how do I send a g-code programme to the machine - or is it really as simple as the obvious old command line trick of ‘COPY p0001.nc COM1’.... be nice if so, but in this case, how does the lathe handle CR-LF and EOF characters? Does it need or expect a particular format??
- How do I find out what version of PCNC the machine is running?
- - When I run the lathe in manual mode and get an error message on the green screen – for example ‘X axis limits exceeded’ – how do I clear this? Hitting ‘reset’ or ‘enter’ etc don’t do anything and at the moment, the only way I can find to clear the message is to power off the control unit.
- If I press one of the spindle buttons in manual mode, it asks me to enter an RPM between 100 and 150. Spindle starts ok but I cant get it to go above 200 rpm or below 100 using the + and – keys. The manual says ‘programmable 0-2000 rpm’, so what am I doing wrong? In case it matters, this lathe has a nice big air-powered chuck on it, not a conventional manual one.
- The machine has the I/Ps and AUX ports mentioned in another append on this forum, but they’re not in the manual. Any idea what they are for? The machine does not have an autochanger, and as far as I can see, has never been fitted with one.
- It does however have an extra box about 12 by 9 by 5 inches in size bolted to the outside of the casing at the spindle end. This contains a 25v power supply and what look like relays or chunky contactors – three of them. Curiously, this box also has on the outside a pair of D-shell connectors the same size as said AUX and IPS ports, but I have neither information nor cables. Any ideas what it was for? My best guess is ‘bar feeder’ but there is no sign of one being fitted. It’s possible that it was for an autochanger – three power feeds presumably corresponding to ‘revolve forward, ‘revolve reverse’, and ‘lock’ – but the electrics seem a bit over-the-top for such a mundane application. They look serious enough to switch a small electrical power station on and off with. Any ideas?
Many thanks in advance, and best regards,
Rick Turner
![:delirious:](./images/smilies/delirious.gif)
