new jaws
hpe
new jaws
Post by hpe » Sun 03 Mar , 2019 20:08 pm
hi i have a cyclone and i need some external jaws for it ...i cannot see any manufacturer on the chuck just the numbers H13665 its 125mm with 35mm through hole 95mm recess
the jaws have 716 stamped on them
does anyone know what chuck i have and where to get jaws
cheers
jamesgates1000
Hardware/Software: 2001 Cyclone with toolchanger and Fanuc 21i control
Serial number - H00913.
Voltage 415V F.L.C 20A 50Hz 3Ph
1997 Triac VMCwith toolchanger and Fanuc O-M control
Serial number - 70826B.
Voltage 415V F.L.C 30A 50Hz 3Ph
Re: new jaws
Post by jamesgates1000 » Thu 07 Mar , 2019 10:48 am
Mine was fitted with a Pratt Burnerd 125mm chuck with the same dimensions that you have.
I need hard jaws also, I found these on ebay...
https://www.ebay.co.uk/i/362560172564?chn=ps
I bought a nice new two piece jaw chuck for mine from cutwel for just over £300
https://www.cutwel.co.uk/workholding/sc ... 275-series
hpe
Re: new jaws
Post by hpe » Fri 08 Mar , 2019 18:59 pm
thank you
do you or anyone know the taper on the spindle which locates the backplate for a chuck ?
DavidB
Re: new jaws
Post by DavidB » Fri 08 Mar , 2019 21:40 pm
The data for the Cyclone here viewtopic.php?f=33&t=3823 says the spindle is A2 3" and some data here about the dimensions https://www.lathes.co.uk/spindlenose/spindlenoses.pdf . From memory the taper is 1 in 4 on diameter but worth a bit of simple trigonometry to check against the taper shown.
Lone_Ranger
Re: new jaws
Post by Lone_Ranger » Fri 08 Mar , 2019 23:23 pm
Could possibly be a Bison/Toolmex chuck, if you measure one of your jaws up, length, width, slot and screw pitch and go to the Rotagrip site there is a fair chance you will find the right jaws for your chuck, I got all my stuff from them when I had my 2 Cyclones a few years ago. Link here :-
https://www.rotagriponline.com/index.php ... &Itemid=29
Rob
