Parameters for a FANUC 21i-T for a Cyclone?
matheusgclassen
Post by matheusgclassen » Thu 12 Sep , 2024 19:08 pm
I'm trying to run a Cyclone machine with a FANUC 21i-T controller that has been sitting idle for a while and want to verify the parameters. As we're having issues running even basic G code instructions.
Machine serial code is: EO5415
Electronics serial code is: E98YAO344
is there a file with the factory parameters for this setup available?
Re: Parameters for a FANUC 21i-T for a Cyclone?
Post by Martin » Tue 17 Sep , 2024 11:49 am
Hope the attached help
CYC6ALL.txt
(32.65 KiB) Downloaded 393 times
EO5415.DOC
(29.5 KiB) Downloaded 406 times
matheusgclassen
Post by matheusgclassen » Mon 23 Sep , 2024 22:58 pm
Thank you, exported the parameters from my machine and was able to compare and find the source of the problem. Someone had messed with the parameters on the machine and it was acting all sorts of weird :?
matheusgclassen
Post by matheusgclassen » Mon 23 Sep , 2024 23:03 pm
Speaking of, the machine doesn't return to zero on startup or save any of its offsets when turning off and on. Would you suggest loading the full file? What can I look at to diagnose the source of that issue?
