Cyclone machine parameters
Post by Martin » Thu 19 Aug , 2010 10:10 am
Cyclone OT-A & OT-B/OT-C parameters.
CYCLONE.zip
(2.1 KiB) Downloaded 2130 times
CYCLONEA.zip
(1.17 KiB) Downloaded 1886 times
ti nut
Hardware/Software: Cyclone TU150-P
Fanuc OT-C
Re: Cyclone machine parameters
Post by ti nut » Fri 12 Oct , 2018 16:35 pm
Is there any chance the zip files are corrupted? Tried to download and open both files, with different browsers and unzipping software but both seem to be incomplete/corrupted - 0T-A after #0171 and 0T-B&C after #0507.
There is always the chance that I'm missing something entirely..
Post by Martin » Mon 15 Oct , 2018 7:53 am
Have posted again.
CYCLONEA.zip
(1.17 KiB) Downloaded 1270 times
CYCLONE.zip
(2.1 KiB) Downloaded 1239 times
ti nut
Fanuc OT-C
Post by ti nut » Tue 16 Oct , 2018 9:32 am
Thank you for updating these Martin.
Are there 900 series parameters for the 0T-A? The file for the 0T-B&C have these.
Thank you!
Post by Martin » Tue 16 Oct , 2018 10:48 am
The 900 parameters are the Fanuc options so were different on each machine as with the 450 diagnostics.
If you let me have the serial number I may be able to locate a copy.
ti nut
Fanuc OT-C
Post by ti nut » Tue 16 Oct , 2018 14:13 pm
Thank you for this.
The machine serial number is CY22129 G
It is a Jan '90 build with 0T-A control
Are the 450 diagnostics set based on viewtopic.php?f=33&t=2916 ?
Thank you!
Post by Martin » Wed 17 Oct , 2018 7:26 am
Hope this helps.
DOC171018.zip
(254.25 KiB) Downloaded 1478 times
GRAY -ARCHERY
Hardware/Software: Fanuc -Fusion 360
Post by GRAY -ARCHERY » Thu 21 Sep , 2023 13:05 pm
Hi There, I am looking at purchasing a Harrison TU150 P. Serial Number TP0011. Is this an OT A,B or C machine and do you have an original copy of the parameters? Electrics Serial 3061795
Post by Martin » Fri 22 Sep , 2023 8:18 am
It will be a FANUC OTA Control.
Attached is the Electrical Record Sheet for TP0011 although the control serial number is different.
TP0011_1.DOC
(26.5 KiB) Downloaded 715 times
