correct parameters?
correct parameters?
Hi, we have just got a Cyclone (CY03079B) when it arrived to us it had already lost its parameters, I've typed them in from the sticky parameters post and that has made the '404 Servo Alarm (VRDY ON)' go and I can now zero return and start the spindle.
my problems are that :
1 the spindle doesn't run at the correct speed
2 I can't toolchange either in Program or with the Jog with the panel switch
if I program S500 the the screen tells me SACT is 275
if I program T0101 the cycle start light stays on but nothing happens, the the panel switch it give me a 'OPTIONS?' alarm
I'm assuming that I've entered some parameters incorrectly?
- IMG_20190606_133005.jpg (239.9 KiB) Viewed 18993 times
- IMG_20190606_132024.jpg (203.6 KiB) Viewed 18993 times
Re: correct parameters?
am I correct in saying that I need to set diagnostic 451.0 to 1 to set my machine for the six station Baruffaldi-TOE80 turret? if so how? I've tried to setting PWE to 1 in MDI as I did to input the main parameters but it doesn't let me make the change
Good morning all, the diagnostic changing problem was down to a dodgy program protect key switch, so only the spindle problem remaining! any ideas?
It's a long time since I have worked on one of these.
Have you set diagnostic 453 bit 0 to a 1? (It only changes momentarily) Diagnostic Setup Marker).
hi Martin, just tried that its not changed the speed problem
could it have anything to do with tuning this drive?
I dont have any documentation on itRe: correct parameters?
It could be. Not sure if we have any documents either.
Does it say what model it is?
here is all the markings I can see
- IMG_20190607_111740.jpg (269.62 KiB) Viewed 18970 times
- IMG_20190607_111814.jpg (179.29 KiB) Viewed 18970 times
is there any chance of a copy of the original parameters for my machine? # is CY 03079B
I won’t get chance to have a look for them until Monday afternoon.
If you could have a look this afternoon that would be greatly appreciated.
We don't have a copy of the 450 Diagnostics for this machine.
I have attached a scanned copy of the info in the file at Denfords.
(parameter list for cyclone fitted with Fanuc 0T-A from July 1989)
N0001 P 11000000
N0002 P 10000010
N0003 P 00000000
N0004 P 01111001
N0005 P 00110100
N0006 P 01111001
N0007 P 00000000
N0008 P 01000011
N0009 P 11101111
N0010 P 11100100
N0011 P 00100000
N0012 P 00000001
N0013 P 00000001
N0014 P 01010100
N0015 P 10010000
N0016 P 00000000
N0017 P 01111111
N0018 P 00000000
N0019 P 00000000
N0020 P 00000000
N0021 P 00000000
N0022 P 00000000
N0023 P 00000000
N0024 P 01000100
N0025 P 00000000
N0026 P 00000000
N0027 P 00000000
N0028 P 00000001
N0029 P 00000000
N0030 P 00000001
N0031 P 00000001
N0032 P 00000000
N0033 P 00000000
N0034 P 00000000
N0035 P 00000000
N0036 P 00000000
N0037 P 00000000
N0038 P 10100100
N0039 P 00000000
N0040 P 00000000
N0100 P 00000002
N0101 P 00000002
N0102 P 00000002
N0103 P 00000000
N0104 P 00000000
N0105 P 00000000
N0106 P 00000000
N0107 P 00000000
N0108 P 00000100
N0109 P 00000015
N0110 P 00000255
N0111 P 00000000
N0112 P 00000000
N0113 P 00000000
N0114 P 00000000
N0115 P 00000000
N0116 P 00000000
N0117 P 00000000
N0118 P 00000004
N0119 P 00000032
N0120 P 00000099
N0121 P 00000100
N0122 P 00000000
N0123 P 00000004
N0124 P 00000000
N0125 P 00000000
N0126 P 00000000
N0127 P 00000000
N0128 P 00000000
N0129 P 00000000
N0130 P 00000001
N0131 P 00000002
N0132 P 00000003
N0133 P 00000004
N0134 P 00000000
N0135 P 00000000
N0136 P 00000000
N0137 P 00000000
N0138 P 00000000
N0139 P 00000000
N0140 P 00000079
N0141 P 00000080
N0142 P 00000084
N0143 P 00000046
N0144 P 00000083
N0145 P 00000084
N0146 P 00000079
N0147 P 00000080
N0148 P 00000073
N0149 P 00000078
N0150 P 00000084
N0151 P 00000069
N0152 P 00000082
N0153 P 00000078
N0154 P 00000065
N0155 P 00000076
N0156 P 00000000
N0157 P 00000000
N0158 P 00000000
N0159 P 00000000
N0160 P 00000000
N0161 P 00000000
N0162 P 00000000
N0163 P 00000000
N0164 P 00000000
N0165 P 00000000
N0166 P 00000000
N0167 P 00000000
N0168 P 00000000
N0169 P 00000000
N0170 P 00000000
N0171 P 00000000
N0172 P 00000000
N0173 P 00000000
N0174 P 00000000
N0175 P 00000000
N0176 P 00000000
N0177 P 00000000
N0178 P 00000000
N0179 P 00000000
N0180 P 00000000
N0181 P 00000000
N0182 P 00000000
N0183 P 00000000
N0184 P 00000000
N0185 P 00000000
N0186 P 00000000
N0187 P 00000000
N0188 P 00000000
N0189 P 00000000
N0190 P 00000000
N0191 P 00000000
N0192 P 00000000
N0193 P 00000000
N0194 P 00000000
N0195 P 00000000
N0196 P 00000000
N0197 P 00000000
N0198 P 00000000
N0199 P 00000000
N0200 P 00000000
N0201 P 00000000
N0202 P 00000000
N0203 P 00000000
N0204 P 00000000
N0205 P 00000000
N0206 P 00000000
N0207 P 00000000
N0208 P 00000000
N0209 P 00000000
N0210 P 00000000
N0211 P 00000000
N0212 P 00000000
N0213 P 00000000
N0214 P 00000000
N0215 P 00000000
N0216 P 00000000
N0217 P 00000000
N0218 P 00000000
N0219 P 00000031
N0500 P 00000020
N0501 P 00000020
N0502 P 00000005
N0503 P 00000000
N0504 P 00008333
N0505 P 00004166
N0506 P 00008333
N0507 P 00000000
N0508 P 00000000
N0509 P 00000000
N0510 P 00000000
N0511 P 00000000
N0512 P 00001843
N0513 P 00003686
N0514 P 00002000
N0515 P 00000000
N0516 P 00001000
N0517 P 00003000
N0518 P 00005000
N0519 P 00005000
N0520 P 00007500
N0521 P 00000000
N0522 P 00000100
N0523 P 00000100
N0524 P 00001000
N0525 P 00000000
N0526 P 00000100
N0527 P 00005000
N0528 P 00000500
N0529 P 00000030
N0530 P 00001000
N0531 P 00000080
N0532 P 00000025
N0533 P 00000000
N0534 P 00000250
N0535 P 00000000
N0536 P 00000000
N0537 P 00000000
N0538 P 00000000
N0539 P 00000-50
N0540 P 00005000
N0541 P 00000000
N0542 P 00000000
N0543 P 00000000
N0544 P 00000000
N0545 P 00000000
N0546 P 00000009
N0547 P 00000000
N0548 P 00000000
N0549 P 00000000
N0550 P 00000010
N0551 P 00000100
N0552 P 00000010
N0553 P 00000006
N0554 P 00000000
N0555 P 00000000
N0556 P 00005000
N0557 P 00000000
N0558 P 00000200
N0559 P 00002000
N0560 P 00004000
N0561 P 00000000
N0562 P 00000000
N0563 P 00000000
N0564 P 00000000
N0565 P 00000000
N0566 P 00000000
N0567 P 00000000
N0568 P 00000000
N0569 P 00000000
N0570 P 00000000
N0571 P 00000000
N0572 P 00000000
N0573 P 00000000
N0574 P 00000000
N0575 P 00000000
N0576 P 00000000
N0577 P 00000000
N0578 P 00000000
N0579 P 00000000
N0580 P 00002000
N0581 P 00000000
N0582 P 00000000
N0583 P 00000000
N0584 P 00000075
N0585 P 00007500
N0586 P 00007500
N0587 P 00000019
N0588 P 00000018
N0589 P 00000020
N0590 P 00000030
N0591 P 00000000
N0592 P 00000000
N0593 P 00000100
N0594 P 00000100
N0595 P 00000100
N0596 P 00000000
N0597 P 00000000
N0598 P 00000000
N0599 P 00000000
N0700 P 00002000
N0701 P 00001000
N0702 P 00000000
N0703 P 00000000
N0704 P-00188000
N0705 P-00209000
N0706 P 00000000
N0707 P 00000000
N0708 P 00000000
N0709 P 00000000
N0710 P 00000000
N0711 P 00000000
N0712 P 00005000
N0713 P 00000000
N0714 P 00000000
N0715 P 00000000
N0716 P 00000000
N0717 P 00000500
N0718 P 00000500
N0719 P 00000500
N0720 P 00000500
N0721 P 00000001
N0722 P 00000500
N0723 P 00000003
N0724 P 00000060
N0725 P 00000150
N0726 P 00000150
N0727 P 00000000
N0728 P 09999999
N0729 P 09999999
N0730 P 00000000
N0731 P 00000000
N0732 P 00000000
N0733 P 00000000
N0734 P 00000000
N0735 P 00000000
N0736 P 00000000
N0737 P 00000000
N0738 P 00000000
N0739 P 00000000
N0740 P 00000000
N0741 P 00000000
N0742 P 00000000
N0743 P 00000000
N0744 P 00000000
N0745 P 00000000
N0746 P 00000000
N0747 P 00000000
N0748 P 00000000
N0749 P 00000000
N0750 P 00000000
N0751 P 00000000
N0752 P 00000000
N0753 P 00000000
N0754 P 00000000
N0755 P 00000000
N0756 P 00000000
N0757 P 00000000
N0758 P 00000000
N0759 P 00000000
N0001 P 11000000
N0002 P 10000010
N0003 P 00000000
N0004 P 01111001
N0005 P 00110100
N0006 P 01111001
N0007 P 00000000
N0008 P 01000011
N0009 P 11101111
N0010 P 11100100
N0011 P 00100000
N0012 P 00000001
N0013 P 00000001
N0014 P 01010100
N0015 P 10010000
N0016 P 00000000
N0017 P 01111111
N0018 P 00000000
N0019 P 00000000
N0020 P 00000000
N0021 P 00000000
N0022 P 00000000
N0023 P 00000000
N0024 P 01000100
N0025 P 00000000
N0026 P 00000000
N0027 P 00000000
N0028 P 00000001
N0029 P 00000000
N0030 P 00000001
N0031 P 00000001
N0032 P 00000000
N0033 P 00000000
N0034 P 00000000
N0035 P 00000000
N0036 P 00000000
N0037 P 00000000
N0038 P 10100100
N0039 P 00000000
N0040 P 00000000
N0100 P 00000002
N0101 P 00000002
N0102 P 00000002
N0103 P 00000000
N0104 P 00000000
N0105 P 00000000
N0106 P 00000000
N0107 P 00000000
N0108 P 00000100
N0109 P 00000015
N0110 P 00000255
N0111 P 00000000
N0112 P 00000000
N0113 P 00000000
N0114 P 00000000
N0115 P 00000000
N0116 P 00000000
N0117 P 00000000
N0118 P 00000004
N0119 P 00000032
N0120 P 00000099
N0121 P 00000100
N0122 P 00000000
N0123 P 00000004
N0124 P 00000000
N0125 P 00000000
N0126 P 00000000
N0127 P 00000000
N0128 P 00000000
N0129 P 00000000
N0130 P 00000001
N0131 P 00000002
N0132 P 00000003
N0133 P 00000004
N0134 P 00000000
N0135 P 00000000
N0136 P 00000000
N0137 P 00000000
N0138 P 00000000
N0139 P 00000000
N0140 P 00000079
N0141 P 00000080
N0142 P 00000084
N0143 P 00000046
N0144 P 00000083
N0145 P 00000084
N0146 P 00000079
N0147 P 00000080
N0148 P 00000073
N0149 P 00000078
N0150 P 00000084
N0151 P 00000069
N0152 P 00000082
N0153 P 00000078
N0154 P 00000065
N0155 P 00000076
N0156 P 00000000
N0157 P 00000000
N0158 P 00000000
N0159 P 00000000
N0160 P 00000000
N0161 P 00000000
N0162 P 00000000
N0163 P 00000000
N0164 P 00000000
N0165 P 00000000
N0166 P 00000000
N0167 P 00000000
N0168 P 00000000
N0169 P 00000000
N0170 P 00000000
N0171 P 00000000
N0172 P 00000000
N0173 P 00000000
N0174 P 00000000
N0175 P 00000000
N0176 P 00000000
N0177 P 00000000
N0178 P 00000000
N0179 P 00000000
N0180 P 00000000
N0181 P 00000000
N0182 P 00000000
N0183 P 00000000
N0184 P 00000000
N0185 P 00000000
N0186 P 00000000
N0187 P 00000000
N0188 P 00000000
N0189 P 00000000
N0190 P 00000000
N0191 P 00000000
N0192 P 00000000
N0193 P 00000000
N0194 P 00000000
N0195 P 00000000
N0196 P 00000000
N0197 P 00000000
N0198 P 00000000
N0199 P 00000000
N0200 P 00000000
N0201 P 00000000
N0202 P 00000000
N0203 P 00000000
N0204 P 00000000
N0205 P 00000000
N0206 P 00000000
N0207 P 00000000
N0208 P 00000000
N0209 P 00000000
N0210 P 00000000
N0211 P 00000000
N0212 P 00000000
N0213 P 00000000
N0214 P 00000000
N0215 P 00000000
N0216 P 00000000
N0217 P 00000000
N0218 P 00000000
N0219 P 00000031
N0500 P 00000020
N0501 P 00000020
N0502 P 00000005
N0503 P 00000000
N0504 P 00008333
N0505 P 00004166
N0506 P 00008333
N0507 P 00000000
N0508 P 00000000
N0509 P 00000000
N0510 P 00000000
N0511 P 00000000
N0512 P 00001843
N0513 P 00003686
N0514 P 00002000
N0515 P 00000000
N0516 P 00001000
N0517 P 00003000
N0518 P 00005000
N0519 P 00005000
N0520 P 00007500
N0521 P 00000000
N0522 P 00000100
N0523 P 00000100
N0524 P 00001000
N0525 P 00000000
N0526 P 00000100
N0527 P 00005000
N0528 P 00000500
N0529 P 00000030
N0530 P 00001000
N0531 P 00000080
N0532 P 00000025
N0533 P 00000000
N0534 P 00000250
N0535 P 00000000
N0536 P 00000000
N0537 P 00000000
N0538 P 00000000
N0539 P 00000-50
N0540 P 00005000
N0541 P 00000000
N0542 P 00000000
N0543 P 00000000
N0544 P 00000000
N0545 P 00000000
N0546 P 00000009
N0547 P 00000000
N0548 P 00000000
N0549 P 00000000
N0550 P 00000010
N0551 P 00000100
N0552 P 00000010
N0553 P 00000006
N0554 P 00000000
N0555 P 00000000
N0556 P 00005000
N0557 P 00000000
N0558 P 00000200
N0559 P 00002000
N0560 P 00004000
N0561 P 00000000
N0562 P 00000000
N0563 P 00000000
N0564 P 00000000
N0565 P 00000000
N0566 P 00000000
N0567 P 00000000
N0568 P 00000000
N0569 P 00000000
N0570 P 00000000
N0571 P 00000000
N0572 P 00000000
N0573 P 00000000
N0574 P 00000000
N0575 P 00000000
N0576 P 00000000
N0577 P 00000000
N0578 P 00000000
N0579 P 00000000
N0580 P 00002000
N0581 P 00000000
N0582 P 00000000
N0583 P 00000000
N0584 P 00000075
N0585 P 00007500
N0586 P 00007500
N0587 P 00000019
N0588 P 00000018
N0589 P 00000020
N0590 P 00000030
N0591 P 00000000
N0592 P 00000000
N0593 P 00000100
N0594 P 00000100
N0595 P 00000100
N0596 P 00000000
N0597 P 00000000
N0598 P 00000000
N0599 P 00000000
N0700 P 00002000
N0701 P 00001000
N0702 P 00000000
N0703 P 00000000
N0704 P-00188000
N0705 P-00209000
N0706 P 00000000
N0707 P 00000000
N0708 P 00000000
N0709 P 00000000
N0710 P 00000000
N0711 P 00000000
N0712 P 00005000
N0713 P 00000000
N0714 P 00000000
N0715 P 00000000
N0716 P 00000000
N0717 P 00000500
N0718 P 00000500
N0719 P 00000500
N0720 P 00000500
N0721 P 00000001
N0722 P 00000500
N0723 P 00000003
N0724 P 00000060
N0725 P 00000150
N0726 P 00000150
N0727 P 00000000
N0728 P 09999999
N0729 P 09999999
N0730 P 00000000
N0731 P 00000000
N0732 P 00000000
N0733 P 00000000
N0734 P 00000000
N0735 P 00000000
N0736 P 00000000
N0737 P 00000000
N0738 P 00000000
N0739 P 00000000
N0740 P 00000000
N0741 P 00000000
N0742 P 00000000
N0743 P 00000000
N0744 P 00000000
N0745 P 00000000
N0746 P 00000000
N0747 P 00000000
N0748 P 00000000
N0749 P 00000000
N0750 P 00000000
N0751 P 00000000
N0752 P 00000000
N0753 P 00000000
N0754 P 00000000
N0755 P 00000000
N0756 P 00000000
N0757 P 00000000
N0758 P 00000000
N0759 P 00000000
- CY03079B.pdf
- (337.16 KiB) Downloaded 1015 times
Thank you very much Martin, I'll put them in later and see if it fixes the speed issue
