please help me find software for TU150-E lathe
runzhilin@gmail.com
Hardware/Software: TU150E
Post by runzhilin@gmail.com » Thu 07 Dec , 2017 7:44 am
There is a TU150-E lathe,with the hard disk driver damage and the soft disk lost, we can not get it work again,which software can i use to get it work again?
thanks so much!
Re: please help me find software for TU150-E lathe
Post by Martin » Thu 07 Dec , 2017 13:51 pm
You can download the TU150 softwarefrom,
https://website.denford.ltd.uk/dos-vinta ... formation/
You will need the Flstep & Drivers2 & make it a boot disc.
mike2424
Hardware/Software: cyclone tu150e /fanuc
Post by mike2424 » Fri 08 Dec , 2017 15:52 pm
I see you have the serial number EO5299, I have the same machine with serial number EO5266 manufactured in November. Small world I guess. Mike
runzhilin@gmail.com
Post by runzhilin@gmail.com » Fri 08 Dec , 2017 17:52 pm
Thanks Martin!
I have created DOS on harddriver and boot ,decompress "drivers2" and "flstep" to C:\denford .Which drivers in "drivers2" do i need to
load for the motion card(link to com3) , and keypad on desk-top TUTRO (link to com2), what should be add into "autoexec.bat"?
runzhilin@gmail.com
Post by runzhilin@gmail.com » Fri 08 Dec , 2017 17:54 pm
hello mike2424!
Does your machine use dos?
mike2424
Post by mike2424 » Sat 09 Dec , 2017 13:03 pm
Yes it uses dos. I am in the learning mode at this time as I try to spend time with it between jobs here in the shop. I want to use the machine to make taper pins, but I keep screwing up the programming. Maybe a couple more beers and it will all make sense. Mike
Edis
Hardware/Software: Harrison TU150U -96
Post by Edis » Sun 10 Dec , 2017 9:58 am
I have a TU150U, but probably the same procedure, did you see this post:
viewtopic.php?p=20455#p20455
Post by Martin » Mon 11 Dec , 2017 12:28 pm
These are the Flstep.go & Flstep.opt files that were sent out with the machine.
You will need to copy the files over the standard set on the disc.
FLSTEP.GO
IBM.RS2 2
$3F8 4 COM1
$3E8 5 MACHINE
DENFORD1.KBD 1
18.2 $2F8 3
VGA.CRT 0
Flstep.APP
FLSTEP.OPT
{--------CIM Settings------------
EXTCOMM_ENABLE 1
EXTCOMM_ROUTE 1
EXTCOMM_SDEVICE COM1
EXTCOMM_BAUD 4800
EXTCOMM_PARITY 0
EXTCOMM_DATABITS 8
EXTCOMM_STOPBITS 1
EXTCOMM_LF 1
EXTCOMM_ES 1
EXTCOMM_EE 2
REMOTECHUCK 1
autoerror 0
dragmarking 0
displaysize 3 {PRODUCT OPTIONS FILE AS OF 18/09/96
narrowsimbox 0 {FOR MIRAC
utils_menu_1 Dos Access
utils_go_1 dos
utils_menu_2 Turning Designer
utils_go_2 ldesign
mirac_sdevice machine
showtool 0
{--------FEEDS & SCALING--------
SLAVE_ACCEL 120
rem mint_mfact 200
HIGHFEED 3000
HIGHFEEDZ 3000
{--------SPINDLE----------------
slave_spindlelag 35
safespindle 150
slave_encoder 2000
slave_spindlef 0.85
slave_thread 1
highspindle 5000
{--------TOOLPOST---------------
SLAVE_ATC 2
MAXTOOL 8
{---------X-AXIS-----------------
MACHINEEXTENTX 140
MOVERANGEX 94
CHUCKCENTREX 50
CHUCKX 80
JAWSX 10
BILLETX 30
{---------Z-AXIS-----------------
MACHINEEXTENTZ 229
MOVERANGEZ 199
CHUCKZ 20
JAWSZ 10
BILLETZ 50
{--------MISCELLANEOUS FUNCS-----
datumorder 0
inspect 1
nopots 0
noair 0
slave_pchuck 1
footswitch 2
lubesense 1
slave_io 1
runzhilin@gmail.com
Post by runzhilin@gmail.com » Tue 12 Dec , 2017 12:11 pm
thanks Martin !!
Can I download these two files from the website or only create them myself?
Post by Martin » Tue 12 Dec , 2017 12:36 pm
They should have both been created when you downloaded the FLSTEP software. You can just replace the text in the files to suit.
