Cyclone turret alignment issue
Re: Cyclone turret alignment issue
Post by Martin » Tue 14 Dec , 2010 11:32 am
Is it the centre line or centre height that's out?
H12UAJ
Post by H12UAJ » Tue 14 Dec , 2010 13:36 pm
centre line
Post by Martin » Tue 14 Dec , 2010 13:53 pm
What model of Fanuc control is fitted?
H12UAJ
Post by H12UAJ » Tue 14 Dec , 2010 17:22 pm
GE Fanuc Series 21i-T
Post by Martin » Tue 14 Dec , 2010 17:40 pm
Do you know if it has datum switches fitted?
You need to reset the X axis home position which is a bit tricky.
There is a procedure sheet that tells you how to set it. I should be able to add a coppy next time I am in the office. (Next Monday)
Post by Martin » Tue 21 Dec , 2010 17:19 pm
Reference procedure for a Fanuc 21I without reference switches.
Refeerence procedure Fanuc 21I.pdf
(24.73 KiB) Downloaded 1353 times
