Hi all,
Well, the old beast is up and running now, thanks to everyone's help, including Curtis from CNC Doctors. Turns out we had a bad sensor in the drive motor plus a broken wire going to the sensor (which probably messed up the sensor).
I have another issue to fix (hopefully my last one for a while) and that is a roaring spindle bearing. Does anyone have an exploded diagram. parts list and disassembly / assembly instructions for the Cyclone spindle?
Dang, I just figured out that I need to buy CNC Lathe software : ). Is this a hobby?
Thanks all,
Bill Gillen
Roaring Spindle
- Hardware/Software: 1988 Cyclone with Fanuc OT-B
Re: Roaring Spindle
This should help:
viewtopic.php?f=33&t=3099
Re: Roaring Spindle
Thank you so much (again) for the help. I used the diagram to help take it apart, and now have new bearings on order. They should be here today or tomorrow. The outside bearing of the double bearing, closest to the chuck, was definitely bad. Reckon it was coolant that messed it up?
I have another question. Is it possible to buy a Cyclone / Fanuc operating manual on this site?
Thanks again,
Bill Gillen
Thanks again,
Bill Gillen
Re: Roaring Spindle
I'm not sure what the legalities are regarding older fanuc .pdf manuals.
I contacted Fanuc recently requesting .pdf manuals and never got a reply (it's worth noting that NUM on the other hand, were very helpful and provided .pdf copies of all the paper manuals we had)
I know there are some floating around the internet and have even managed to find 0A/0B/0C ones on gefanuc sites in the past, but as it's copyright we can't put them on here. If you know the number of the manual it helps when googling for it (eg 61410 was the 0TC parameter manual)
Some get sold on ebay so keep an eye out there as well.
Re: Roaring Spindle
PS, the 0TB operators manual is 60124e
