Compact 1000 using VR Milling v2.31
Posted: Wed 10 Oct , 2007 20:36 pm
by boots
What do I need to change to run the Compact 1000 with VR Milling v2.31?
Posted: Wed 10 Oct , 2007 20:40 pm
by boots
Change the settings for the Router Compact NS to use a Compact 1000 in VR Milling v2.31
Under the Setup tab click on Setup Machine Parameters
Right click on Router Compact NS – Set as active machine,
Change the values as listed.
HOME
X 0
Y 0
Z 0
Feed 1300
Negative X CHECK
Negative Y uncheck
Negative Z CHECK
Negative IV uncheck
Home Time Out 55000
FEED
Default 100
Max Rate X 5000
Max Rate Y 5000
Max Rate Z 5000
Max Rate IV 1500
Min Rate 20
Steps per mill X 40
Steps per mill Y 40
Steps per mill Z 40
Steps per mill IV 80
Steps per mill F 40
Motor Direction X 1
Motor Direction Y 1
Motor Direction Z 1
Motor Direction IV 1
Max Contour Feed 3000
Max Contour Angle 35
Upper Contour Angle 90
Contour creep 0.1
Jog Rapid Feed 4000
Shortest Contour 0
Shortest Feed 0
SPINDLE
Max Speed 23000
Min. Speed 8000
Manual uncheck
MACHINE CAPABILITY
Max Cut Depth 20
Travel X+ 0
Travel Y+ +240
Travel Z+ 0
Travel IV 9999
Travel X- -400
Travel Y- 0
Travel Z- -110
Travel IV- -9999
Cutter Comp. CHECK
High Speed Mach CHECK
Table Size X 412
Table Size Y 240
Table Size Z 40
Under Insp. Uncheck
Feed Pot CHECK
Speed Pot uncheck
Real Mach Avail CHECK
Expand Arcs uncheck
Min. Chord 1
IV Axis 0
IV Home Switch uncheck
