Hi all,
I had a problem with 2D Design today and am hoping someone may be able to shed some light on it for me! I was unable to export my 2D Design file to an FNC file. I was using File - Plot - Microrouter link as I always have done (and had been using the machine in this way all day with no problems). Neither had I done anything different with the files or the way I set the machining parameters up.
When I opened up VR Milling and tried to find the FNC file, I could only find a saved .dtd file instead. I re-tried everything I could think of to save the design but it still kept returning as a .dtd file.
Please can someone help?
Thanks,
Zoe
2D Design files (DTD) not exporting to (FNC) even with Plot
In the Folder where the techsoft software is installed there is a file called 2ddes.ini
This file contains the path where the FNC file is created.
By default it will save in C:\DENFORD\DATA
It is possible to change this path. See the other posts.
Check you have read right access to the directory where the files are saved.
You may be logged onto the network as a user without the access rights
viewtopic.php?t=13&highlight=2ddes
viewtopic.php?t=678&highlight=2ddes
Thanks Steve & Bradders,
I'll have a look and see if these things work and get back to you if not...
There was an error message, but I don't remember at this stage what it was - the only thing I remember is that it told me I was trying to load a .dtd file into VRMilling.
Anyway, I'll give it another go...
Cheers!
Zoe
Cheers!
Zoe
