I did a search on this but didn't find any relevant results.
We have recently been looking into using 2D Design to plot to the VR Milling software.
We have run into a problem however...
For testing, we did a very quick single shape.  Then went to "Plot" on the file menu and then to "Ok".  Following this, an error box appears stating that a file called "DenlCall.exe" cannot be found.
We thought that this might be another side effect of our RM CC3 network, but this problem holds true on standalone workstations also that aren't related to the CC3 network.
I just wondered where I would find this file.  Should it have been installed already or is an extra plugin we would have to purchase?
Thanks.
    				    			This is one of our oldish support notes that may shed some light:
https://www.denfordata.com/downloads/DENLCALL.zip
Have you already installed the denford extension for techsoft ?
    				    					You can get the latest denlcall.exe here:A problem has been identified when using TechSoft 2D Design with Denford Extensions on a network.
The problem related to the user wanting to specify seperate directories for the main TechSoft application (with read-only rights) and users data files (with read-write rights).
A new DENLCALL.EXE file has been released that overcomes this problem. All future shipments of TechSoft 2D Design with the Denford extension will have this updated file. This updated file can be obtained by emailing service@denford.co.uk <mailto:service@denford.co.uk>
Technical Information
To specify a new destination directory for the CNC Data files generated by the Denford Extension, add the following entry to the 2DDES.INI file located in the TechSoft 2D Design application directory
[LINKS]
DenfordDataDirectory=N:\MYWORK
See the TechSoft 2D Design help file for more information about the location of its Drawing Data Files
The location of DENLCALL.EXE and DENLANG.DLL is still specified by the following entry in WIN.INI
[Denford Machine Tools]
Directory=P:\APPS\DENFORD\
Last edited by Denford Admin on Wed 16 Jan , 2008 10:45 am, edited 1 time in total.
I downloaded the file from the given link and installed it but, another file was found to be missing!
DENLANG.DLL
Anybody any ideas
    				    			DENLANG.DLL
Anybody any ideas
