LINE ANGLES
Posted: Fri 27 Nov , 2020 14:00 pm
I've been experimenting with the unlicensed version of QuickTURN 2D Design.
If I look at the properties of a line drawn parallel to the X axis its angle is given as 3.54331.
If I look at the properties of a line drawn parallel to the Z axis its angle is given as 7.08661, which is twice the previous figure.
The angles clearly aren't in degrees or radians, so what units are they in? Is there a setting which can be changed to give the angle in degrees?
Thanks.
Thanks.
