I produced the attached drawing using QT2DD (I zipped it because the forums won't accept .lcmfiles)
I then used the CAM Wizard to generate GCode in an .fnl file which is also attatched.
When I simulate running the code using QT2DD the internal turning tool makes a massive cut which would undoubtedly stall or damage a real machine.
The machine tooling and machine materials setting check out OK.
QT2DD Making massive cuts when machining internal arcs.
- internal arc.fnl
- (2.05 KiB) Downloaded 10 times
- internal arc.zip
- (3.11 KiB) Downloaded 11 times
