Problem with repeating loops Access Violation 00536740
paul
Post by paul » Tue 17 Oct , 2006 12:09 pm
Can anyone help me with this
When I use a subprogram it works if I do not set a repeat for example
M98 P0080
This calls program 0080, runs it and returns to the main program no problems
But if I want a loop to execute say 10 times according to the help files I write the line as
M98 P100080
When I do this the loop still only executes once then crashes with this message.
Access Violation at address 00536740 in module 'windmill.exe'. Read of address 00000520.
Ive tried it on a few PC's and its always the same
Any ideas would be great thanks.
Paul
Post by Denford Admin » Tue 17 Oct , 2006 13:03 pm
I've tried it here and get the same thing.
We'll look at the software to see if there is a workaround or fix
Mr Magoo
Post by Mr Magoo » Wed 18 Oct , 2006 12:49 pm
Have you tried putting an 8 digit number in like this...
M98 P00100080
Post by Denford Admin » Wed 18 Oct , 2006 18:24 pm
Nah - still won't work - its a problem with both version 2 and 5 of VR Milling :oops:
Its sorted now in the next releases :D (which will be v2.32 and 5.14)
