VR Milling v5.41 released 23rd Feb 2011
Post by Denford Admin » Wed 23 Feb , 2011 14:49 pm
Check here to download the latest version of all software:
Updates since last version:
V5.39 - Some updates to make sure you can't request another toolchange from the tool offset editor whilst one is already in progress.
V5.39 - update to DXF cam to large arcs being converted with invalid end points. also added ability to turn off linetoarc conversion on the post screen.
V5.39 - Mods to allow ATC to be fitted+removed (live) to Router 2600, 2600 Pro, 6600 and 6600 Pro:
// Input 23 will force the Router 6600/2600 and Router 6600/2600 Pro into doing the ATC sequence and turn on M24 and M25.
// Input 21 will disable CE estop checks on 5414 firmware
// Easyupgrader factory will now let you force a Green LED Nextmove up to 5414 firmware, so that it uses Bigmint3/4 and not .52xx.mnt
// Any none CE 2600's with orange LED top boards should be updated to 5414 and the disable CE link can be fitted - this is so it's not using 55xx.mnt
// Tools/offsets now use a different set if Toolrack parameter is ticked (which is also forced on by the input 23), so the active tool also changes when fitting/refitting spindle motors
v5.40 Made changes to stepperdelay to fix issues with certain stepper drives on the VMC
v5.41 Altered ATC rack sequence so that new tool will still be activated even if seq. is stopped near the end
v5.41 fix to VR machines catastrophic failure in v5.40 and 5.39
dixonsca
Hardware/Software: Denford Magnum router. (now upgraded to a 3d router using retrofit kit macmotion controller and upgraded stepper motors)
Triac PC
Nova mill
Microrouter
Turn 270 Pro
Unimatic 4th axis
Makerbot Replicator 2
VR Milling 5
techsoft 2d design
corel draw
solidworks
artcam
lathecam designer
quickturn 2d
Re: VR Milling v5.41 released 23rd Feb 2011
Post by dixonsca » Thu 10 Mar , 2011 12:56 pm
hi have just in stalled this version on a window xp machine and all looks ok a first glance, machince and pc are talking to each other. however i do seem to have a problem with the overide pots being disabled with a "red x" and i cant seem to find where to enable them. any ideas?
thanks for any help
Post by Denford Admin » Thu 10 Mar , 2011 13:12 pm
Check the parameters:
Menu Setup > Setup Machine Parameters > denny > Machine Capability - Feed pot and Speed Pot should be un-ticked (if you want them to work via software and not real ones on the machine)
dixonsca
Triac PC
Nova mill
Microrouter
Turn 270 Pro
Unimatic 4th axis
VR Milling 5
techsoft 2d design
corel draw
solidworks
artcam
lathecam designer
quickturn 2d
Post by dixonsca » Thu 10 Mar , 2011 14:00 pm
when i click this i get asked for a password, please can you tell me whta it is?
dixonsca
Triac PC
Nova mill
Microrouter
Turn 270 Pro
Unimatic 4th axis
VR Milling 5
techsoft 2d design
corel draw
solidworks
artcam
lathecam designer
quickturn 2d
Post by dixonsca » Thu 10 Mar , 2011 14:04 pm
never mind. i have found the password "denny" elswhere in you forum.
thanks for your help pointing me in the right direction. :)
Post by Denford Admin » Thu 10 Mar , 2011 14:48 pm
There was a clue in my response :wink:
dixonsca
Triac PC
Nova mill
Microrouter
Turn 270 Pro
Unimatic 4th axis
VR Milling 5
techsoft 2d design
corel draw
solidworks
artcam
lathecam designer
quickturn 2d
Post by dixonsca » Thu 10 Mar , 2011 15:59 pm
haha there was indeed.
we are upgrading soon to win 7 is vrmilling compatible?
cheers
Post by Denford Admin » Thu 10 Mar , 2011 16:10 pm
Yes it now runs on windows-7 32bit and 64bit.
