Denford Triac
joey1117
Denford Triac
Post by joey1117 » Sat 18 Aug , 2007 21:13 pm
need some help i bought one of these off ebay and the main board has three blown res. two one the proc. one one the filter i would like to buy a new board from someone one here or just get the values so i can try and repair it let me know
thanks
joe
Post by Steve » Sun 19 Aug , 2007 2:44 am
There are lots of different types of Triac.
Can you post the serial number and some pictures it should help us identify.
joey1117
here is an update
Post by joey1117 » Sun 19 Aug , 2007 13:42 pm
i will get pics and the ser. number later today but i put some power to it and the machine spindle goes real slow in rev without me doing anything i have to leave the emerg.stop button out in the run position then turn om the power the monitors do nothing the small one has a black wire and a spring that is just laying on the bottom of the case. that screen foes nothing at all , the other monitor show green lines buut thats it i cant read anything ,the spindle goes really slow in rev. and none of the axis will move and you can not stop the spindle with any buttons.i had a dyna mill that i could hook a tv up to using the video in rca jack will that work with this as well sounds like the board is crapped out i hope thats all that is wrong with this
joe
joey1117
Post by joey1117 » Sun 19 Aug , 2007 14:01 pm
here is a pic of the board the yellow is where the res. are burnt out
Post by Steve » Sun 19 Aug , 2007 15:10 pm
The electronics you have are made by North East Electronics. Unfortunatley they are very old and now unsupported. :cry: Several people on the forum have replaced these and fitted Mach 3. There are several threads telling you how to do this.
Someone else may have some other suggestions though :?:
joey1117
Post by joey1117 » Sun 19 Aug , 2007 20:58 pm
well i found a guy that will sell me a new mother board for 100.00 us money do you think this will fix the problem? i would not mind converting the system over to use the mach 3 but i have no idea what to buy or how to do it i did try and replace the resisters that were burnt out but it did not help and im not 100% sure i got the right ones in there but i figured it could'nt hurt to do it it doesnt work now .not sure why i have no video through the spring with the black wire sodered to it might be whats wrong but i dont know where that goes
let me know if you can help out on these new questions thanks alot for your time
joe
aarggh
Dead resistors
Post by aarggh » Wed 09 Jan , 2008 12:11 pm
Did you end up sorting out the resistors? As I have just come into possession of what looks the exact same board and have a look andncheck if you want?
Post by Denford Admin » Thu 10 Jan , 2008 12:56 pm
Unless you can replace a couple of components and get it working quickly, I think you are best retrofitting Mach3 like others are doing:
viewtopic.php?t=1108
You could end up spending a lot of time and money on something that isn't that great anyway (small memory / slow / loosing position / 2D only contouring etc...)
Triac whizz
Post by Triac whizz » Thu 10 Jan , 2008 18:36 pm
you can tell he's not from sales :mrgreen:
but yes I agree
www.la-coterie.com
Post by Denford Admin » Fri 11 Jan , 2008 9:59 am
I was (I hope) referring to a machine made in the 80's - when paper tape and ZX81's were the height of technology :D
