Gerber import - drill file in *.txt format
- CNC Apprentice
- Hardware/Software: Quickcam Pro v1.13.0.76
VR Milling v5.63.0.680
Novamill
Microrouter Pro
Win 7 Pro
I am using an app called Fritzing for a PCB design. It is a nice intuitive piece of software that does nearly everything I need, and the copper tracks import fine into VR Milling. However, the drill data is exported in *.txt format and VR Milling is looking for a *.drl format. Any suggestions?
Re: Gerber import - drill file in *.txt format
Can you just use the Auto Drill function? This sets the drill size to the hole size drawn in the pad. It could be worth changing the text file extension from txt to drl it may just work.
- CNC Apprentice
Novamill
Microrouter Pro
Win 7 Pro
Hi Steve, yes I can! I compared the txt with a 'proper' drl and addedd a G81 at the beginning, changed the suffix and it works. Kind of. The scale and origin seem a bit odd. Here's some photos?
I have also used DesignSpark, and those holes work well, but the board seems to be missing half its tracks:
Any thoughts gratefully received!
Is the PCB output set in inch or metric?
Try setting to Metric, It may be a scaling issue with the drill holes.
I would also try a free internet gerber viewer to see if all the tracks are present in the other package.
Are you using the latest version of VR Milling?
Can you attach a couple of gerber and drill files?
- CNC Apprentice
Novamill
Microrouter Pro
Win 7 Pro
Hi - I have attached the two drl files. Both seem to be in inches, but the co-ordinates differ. There doesn't seem to be a 25.4 factor correlation with the two files. (drl files not allowed so they are re-named txt files)
I have tried changing the 'inch' line to 'mm', but it didn't seem to work. Is that the correct term?
Thanks again
Thanks again
- Fritzing file Torch2.0_drill mod.txt
- (766 Bytes) Downloaded 1102 times
- DesignSpark file [torch 2.0 0Li v3.0] - Drill Data - [Through Hole].txt
- (664 Bytes) Downloaded 1134 times
I diont thinkthere will be much we can do with the text file conversion.Could you attach the gerber from design spark?
What version of VR Milling software are you using?
- CNC Apprentice
Novamill
Microrouter Pro
Win 7 Pro
Steve - please just change the suffix to .drl
VR Milling version 5.58.0.658...
I have also checked the DesignSpark PCB output using GraphiCode GC-Prevue, and it looks good. I'll try upgrading the VR milling to the latest version...
