PNC4 Operating manual 1987
Post by Denford Admin » Tue 31 Aug , 2010 11:31 am
I've run this scanned manual through OCR, so it should be searchable
https://www.denfordata.com/downloads/for ... 87-OCR.pdf
reza_m2rn
Re: PNC4 Operating manual 1987
Post by reza_m2rn » Wed 24 Apr , 2013 19:20 pm
Denford Admin wrote:PNC4 Operating manual 1987
Hello,
I am trying to use the PNC-4 controller to draw a circle by G02/03 but it seams like it splits it two 4-5 arcs and it stops after finishing each sub_arc and starts the new one.
Is there any way that O could force the PNC-4 to do it smoothly and once?
Reza
Post by Denford Admin » Thu 25 Apr , 2013 9:47 am
I'm pretty sure the answer will be no.
Arc movement being split into quadrants was probably necessary due to limitations in the stepper control interpolator (in firmware or hardware even?)
reza_m2rn
Post by reza_m2rn » Fri 26 Apr , 2013 0:18 am
Thanks a lot for your reply, I really appreciate that,
But, referring to the section 4.3.3 of the manual, apparently it can be done by changing SWA.4 to on position.
here is the actual context:
" It will be seen that the 350 0 arc in block 2 is split into five
seperate smaller arcs of 21.80 , 90 0 , 90 0 , 90 0 , and 58.2 or each of
which is executed seperately. However, if the continuous constant
feed movement facility (see 2.8) is used, the complete arc will be
profiled in a Single continuous movement."
However, It does the same thing even though I set the SWA.4 to on position.
Do you have any idea?
Reza
Post by Denford Admin » Fri 26 Apr , 2013 8:51 am
Sorry no, none of us here at Denford have any experience or knowledge of the PNC controls (only what we've found and scanned in the manuals)
Try contacting this user who used to work for NEE:
viewtopic.php?f=54&t=2841
reza_m2rn
Post by reza_m2rn » Fri 26 Apr , 2013 16:46 pm
Reza
reza_m2rn
Post by reza_m2rn » Wed 08 May , 2013 7:02 am
Hi Guys,
I have a big problem in drawing arcs using PNC4 controller. They are not neat and
They have like some kind of random distortion on them. I should add that the table is so big and heavy too.
It would be highly appreciated if any one could
help me out of this.
Faithfully,
Reza
Post by Denford Admin » Wed 08 May , 2013 10:23 am
What machine is it ?
Photos would help.
I also think you should start a new topic under the machines section as it now sounds more of a machine problem
reza_m2rn
Post by reza_m2rn » Wed 08 May , 2013 19:17 pm
It's a M800 Electrox laser machin and the table dimension is 94x49 inches.
Reza
reza_m2rn
Post by reza_m2rn » Fri 10 May , 2013 7:34 am
It was the CNC backlash problem ;)
Reza
Post by Denford Admin » Fri 10 May , 2013 8:36 am
That's good to know, sorry we couldn't help more.
Was the backlash mechanically fixed or by the control ?
reza_m2rn
Post by reza_m2rn » Fri 10 May , 2013 8:40 am
That's fine,
The controller is to old to fix the backlash, we made it mechanically.
Reza
