Fly Box made on a Microrouter Compact
Post by Steve » Wed 24 Feb , 2010 11:07 am
I am posting some photos of a fly box project carried out by Middle School Kids in Montana.
The project is done by all in the class where they machine the box themselves. I believe they then manually trim and finish the two halves before engraving a logo of their own design on the Lid.
The project has been run for a few years now and Mark has sent a sequence of photos to show how the fixturing has been developed to make production much more acurate and reliable.
The hardest part of machining these things is holding the work down and positioning the part accurately in reference to the datum position
Re: Fly Box made on a Microrouter
Post by Steve » Wed 24 Feb , 2010 11:08 am
Photos of the fixture to hold the work on the machine bed.
main jig close up.jpg (132.84 KiB) Viewed 9663 times
main jig.jpg (122.41 KiB) Viewed 9663 times
Post by Steve » Wed 24 Feb , 2010 11:11 am
A fixture has also been made to drill the wood blanks before fitting into the machine.
Drilling board.JPG (176.67 KiB) Viewed 9663 times
prepared board.JPG (186.17 KiB) Viewed 9663 times
Post by Steve » Wed 24 Feb , 2010 11:14 am
The next pictures show the material clamped onto the jig and then the two halves of the boxes machined out with recesses for the hinges and magnetic catch.
ready to machine.jpg (103.49 KiB) Viewed 9663 times
boxes machined.JPG (178.75 KiB) Viewed 9663 times
Post by Steve » Wed 24 Feb , 2010 11:26 am
The machined part is removed from the jig and then hand finished as two halves.
Then another fixture is fitted to allow a design to be engraved on the lid.
This fixture is a tight fit on the inside of the machined pocket inside the lid preventing side to side movement, though a couple of wedges are used to hold it down.
lid fitted to jig.JPG (185.72 KiB) Viewed 9663 times
engraving jig for lid.JPG (201 KiB) Viewed 9663 times
Post by Steve » Wed 24 Feb , 2010 11:27 am
Engraving the Lid
Engraved Lid.JPG (177.34 KiB) Viewed 9663 times
Post by Steve » Wed 24 Feb , 2010 11:28 am
The finished fly box shown with magnetic strip and rubber inside.
box inside fitted with rubber and magnetic strip.JPG (181.28 KiB) Viewed 9663 times
Finished box.JPG (154.29 KiB) Viewed 9663 times
Post by Steve » Wed 24 Feb , 2010 11:34 am
Note the modification to the side window in the photos of the box lid fixture.
The machine has been modified to work with shop extraction.
On newer machines always ensure there is somewhere for the air to get into the machine otherwise the windows or guards will be sucked in!!!
