Blue Police Phone Box
- Ronin
- Hardware/Software: Denford Range
Here are the files for making a scale model of the Blue Police Phone Box from a popular BBC Science fiction program.
The majority of the parts were machined on the router using 2 tools, one was a 6.35mm end mill and the other was a 45 degree V.
The finished box is held together with panel pins and PVA.
This was a fun litle project and took about 4 hours to machine.
- Photo of the finished model
- Blue Box.jpg (98.29 KiB) Viewed 27909 times
- Light Top.STL
- ABS 1.75 Blue
UP!Plus or UP! Mini - (290.8 KiB) Downloaded 1261 times
- Windows.dxf
- Vinyl 395x230 Blue
Craft Robo - (19.68 KiB) Downloaded 1292 times
- Window.dxf
- Acrylic 95x110x3 Mirrored
VLS Laser Cutter - (3.28 KiB) Downloaded 1236 times
- Screen shot of the Solid Works Assembly
- Build Photo.png (74.23 KiB) Viewed 27910 times
- Sheet 9.dxf
- MDF 600x330x18
Router 6600 or 2600 - (2.96 KiB) Downloaded 1325 times
- Sheet 8.dxf
- MDF 600x330x18
Router 6600 or 2600 - (4.09 KiB) Downloaded 1260 times
- Sheet 7.dxf
- MDF 600x330x18
Router 6600 or 2600 - (4.81 KiB) Downloaded 1298 times
- Sheet 6.dxf
- MDF 600x330x18
Router 6600 or 2600 - (10.85 KiB) Downloaded 1280 times
- Sheet 5.dxf
- MDF 600x330x18
Router 6600 or 2600 - (12.57 KiB) Downloaded 1333 times
- Sheet 4.dxf
- MDF 600x330x18
Router 6600 or 2600 - (6.48 KiB) Downloaded 1254 times
- Sheet 3.dxf
- MDF 600x330x18
Router 6600 or 2600 - (21.86 KiB) Downloaded 1269 times
- Sheet 1 & 2.dxf
- MDF 600x330x18
Router 6600 or 2600 - (20.41 KiB) Downloaded 1302 times
- PoliceBoxSignOutline.pdf
- Acrylic 220x50x3 White
VLS Laser Cutter - (1.03 KiB) Downloaded 1247 times
- PoliceBoxSign.pdf
- Vinyl 220x50 Black
Craft Robo - (4.68 KiB) Downloaded 1211 times
- DoorSign V2.pdf
- Acrylic 59x85x3 White
VLS Laser Cutter - (24.83 KiB) Downloaded 1256 times
- Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3 - Location: Quatroland
Re: Blue Police Phone Box
all we need now is a full set of dalek plans.
4 Quatros
3 Oracs
2 Easiturn atc
full size please.
Is this a Tardis from Dr Who then ?Blue Police Phone Box from a popular BBC Science fiction program
4 Quatros
3 Oracs
2 Easiturn atc
Might be, i've not looked inside
- Ronin
I'm not allowed to call it a TARDIS as the name belongs to BBC Wales, but it does look like it.
Can I EXTERMINATE this thread?
I don't like DR Who!
Next job: remote controlled K9 !?
