WANTED - Deford Triac ATC In/Out cylinder
jamesgates1000
Serial number - H00913.
Serial number - 70826B.
Post by jamesgates1000 » Mon 26 Oct , 2015 11:30 am
I have pneumatic cylinder on on milling machine tool changer that has a leaking internal seal. It works on the outward stroke but air exhausts out of the back valve on the return stroke.
Does anyone know if I could replace the internal seal on this cylinder?
If not does anyone have a spare lying around?
The cylinder is a Joucomatic Isoclair 435 50 438 c 25 A 150 (P max 140psi)
angel-tech
Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3
Re: WANTED - Deford Triac ATC In/Out cylinder
Post by angel-tech » Tue 27 Oct , 2015 0:27 am
i think the ends are crimped on if so no chance, but the item is replaceable for around £15 upwards.
jamesgates1000
Post by jamesgates1000 » Tue 27 Oct , 2015 7:35 am
Hi, I have been quoted £60+p&p, do you a have any recommendations for a cheaper supplier. Thanks
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Tue 27 Oct , 2015 10:14 am
I managed to get a replacement on ebay for £15, but if you want an original you will pay a lot for it.
jamesgates1000
Post by jamesgates1000 » Tue 17 Nov , 2015 13:11 pm
Thanks for the replies.
Went to my local pneumatic supplier in Bristol(Harrier Pneumatics) and got a Parker PIA-5025MS-0150 as a direct replacement for £64.
ATC is working fine now.
Post by Martin » Tue 17 Nov , 2015 16:33 pm
Thanks for letting us know. Am sure it will help others in the future.
