Denford Mirac Lathe '2000
Karlis
Hardware/Software: Denford Mirac lathe '2000 (serial nr. 00081)
Post by Karlis » Mon 13 Feb , 2012 10:31 am
Need Automatic Indexing 8 Station toolpost for my Denford Mirac Lathe (year 2000, serial nr.00081). I could use some help where to look.. Thanks.
Re: Denford Mirac Lathe '2000
Post by Denford Admin » Mon 13 Feb , 2012 10:43 am
From our records, the machine had a Denford-made DM8 toolpost with Omron drive:
OMRON
3G3JV 0.55KW
N9P1931-001-12
What has happened to the old one ? Does it need replacing or repairing ?
Karlis
Post by Karlis » Mon 13 Feb , 2012 11:28 am
Some parts of it has worn, for example pic - parts inner diameter is now 1,5mm larger; rotary switch (ordered one already) and hooks or jaws (i don't know how to call them :) ). I think it rather needs to be replaced.
Post by bradders » Mon 13 Feb , 2012 11:55 am
Unfortunately we do not have this part
Karlis
Post by Karlis » Mon 13 Feb , 2012 12:10 pm
This specific part or entire toolpost?
Post by bradders » Mon 13 Feb , 2012 12:19 pm
Our designer is off work at the moment, so we will have to wait for his return to see what or if we can offer
Karlis
Post by Karlis » Mon 20 Feb , 2012 11:49 am
Hi! Did he come back?
Post by bradders » Tue 21 Feb , 2012 11:22 am
He's not back yet.
Post by Steve » Tue 21 Feb , 2012 11:44 am
We do not have any parts for the DM 8 turret.
Attached is a link to the turret drawing.
https://www.denfordata.com/projectimages ... rawing.pdf
Can you identify the part you require and we can then have a look to see if there is anything we can do to help?
This post may be helpfull also
viewtopic.php?f=40&t=157
Karlis
Post by Karlis » Thu 08 Mar , 2012 14:04 pm
So, the parts:
TP126/3 - Worm gear
TP126/5 - Reversing Bush
TP126/8 - Locking Pawl
Last week I received and installed new Rotary Switch (Grayhill), now the machine functions a bit better. But I wish to replace all worn parts if possible.
kind regards,
Karlis :)
Karlis
Post by Karlis » Thu 08 Mar , 2012 14:10 pm
One more:
TP126/9 - Locating Pawl
Post by Steve » Thu 08 Mar , 2012 14:32 pm
Sorry to say we dont stock any of the items but the Worm gear was made by Hewwitt & Topham
Royd Way, Keighley, West Yorkshire BD21 3LG United Kingdom Telephone: +44 (0) 1535 602587
I have attached drawings for all the parts. I am sure you can make your own on some of them but can subcontract the others.
Tp126_09_V3.pdf
(271.3 KiB) Downloaded 948 times
Tp126_08_V3.pdf
(271.12 KiB) Downloaded 935 times
TP126_05_V3.pdf
(387.55 KiB) Downloaded 917 times
Tp126_03.pdf
(102.91 KiB) Downloaded 973 times
