mcm to dxf
mcm to dxf
Is there an easy way to convert an mcm file to dxf or autocad dwg?
Regards - John
Regards - John
Re: mcm to dxf
I dont have LaserCAM loaded but it should be the same as QuickCAM 2D.
Once you have your design go to FILE then EXPORT and you have to option to save as a DXF.
Sometimes you can get an error message the first time you do this.
This is a bug in the 3rd party design engine and we cannot get it fixed but the file is still saved and the error does not occur again until you reopen the software.
Re: mcm to dxf
There isn't an export option nor is there an option in Save As......
J
J
Re: mcm to dxf
You're right - LaserCAM does not have the Export option, but QuickCAM 2D has.
There must have been a marketing decision to disable it, as the two pieces of software are identical other than the toolpath CAM wizard in QuickCAM.
Re: mcm to dxf
I think we have quickcam, I'll check.
Thanks - John
Thanks - John
Re: mcm to dxf
Are you running the latest version?
Version 1.11 can be downloaded from, https://www.website.denford.ltd.uk/suppo ... -downloads
Re: mcm to dxf revisited
I am using Windows 7 with Quickcam 2D, when exporting a drawing to .dxf I get this error
Access violation at address036857F4 in module 'VECAD.dll'. Read of address 00000000.
I have tried to export the file in all of the versions V10, V11, V12, V13 etc. The .dxf file does appear where I saved it but there is nothing in it.
Re: mcm to dxf
I'll have to double check it's not a Windows 7 problem, but there has always been an issue with .DXF export.
Unfortunately the library we use isn't supported so we have to put up with it for the time being
Whenever I want to export to .dxf I find the 1st time dosn't work, usually creating an empty file, but if I export again then it works ok.
Re: mcm to dxf
Hi Admin
We are having the same problem with export. It just produces an empty file every time. I have exported a number of times but still the same thing happens. I have loaded the latest version and running Windows XP. Please could you look at this again? I have a job that I need to use this function on.
Many thanks
Matt
Many thanks
Matt
Architectural Model Maker www.matthewwood.co.uk
Re: mcm to dxf
Yes I've just tried it again here on XP with latest version of QuickCAM using DXF file version v13
I got an exception and an empty file the 1st time.
The 2nd time I saved it as a different filename (by mistake) and also got an exception
3rd time I saved into the 1st empty file and it worked fine - It seems as though it errors out when the file doesn't already exist
Re: mcm to dxf
I tried it again today and it worked fine!
I was trying to save the .dxf file to my desktop and it didn't work.
I saved the .mcm file I was trying to export on the desktop and then it all worked fine, and works for other .dxf files, as long as there is a .mcm file where it's going . It’s like you need any .mcm file with it before it works..!?
I know this sounds very weird but I thought I had better post in case it helps anyone else in the future.
Matt
Matt
