QuickCAM 2D Design-Curve Tool problem
Jeff Chandler
Post by Jeff Chandler » Mon 27 Apr , 2009 0:32 am
I have only been using QuickCAM 2D for a short time. The curve tool does not fix the angle of the last point. I have drawn a line using the curve tool, finished the curve and adjusted the angle, then saved. Closed the file, I then gone back to the saved curve and the end of the curve has moved.
I have tried grouping the line, but it does not seem to fix the curve into position. It inverts the final point angle and turn back on itself.
P.s. I have pictures but I do not have permission to attach.
Post by Denford Admin » Mon 27 Apr , 2009 9:19 am
Unfortunately this is a known problem with the 3rd party CAD engine we use.
Keep an eye on the version updates in this forum for any fixes. In the meantime, although not ideal, you could explode the curve before saving
